メインコンテンツにスキップ
Dell Optiplex SX280 Motherboard Replacement
必要な工具と部品
  1. Dell Optiplex SX280 Motherboard Replacement, Panel Cover: 手順 1、 1の画像 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Motherboard Replacement: 手順 2、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 2、 2の画像 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Motherboard Replacement: 手順 3、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 3、 2の画像 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Motherboard Replacement, Heat Sink: 手順 4、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement, Heat Sink: 手順 4、 2の画像 2
    • Remove the large blue cover from the computer, there are no screws or tabs keeping it in place.
  5. Dell Optiplex SX280 Motherboard Replacement: 手順 5、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 5、 2の画像 2
    • Press down on the release tab above the heat sink.
  6. Dell Optiplex SX280 Motherboard Replacement: 手順 6、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 6、 2の画像 2
    • Pull the heat sink out of the computer while pressing on the release tab.
    • When reassembling make sure to clean the processor and heat sink of all old thermal paste and apply new paste to the processor
  7. Dell Optiplex SX280 Motherboard Replacement, Upper Fan: 手順 7、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement, Upper Fan: 手順 7、 2の画像 2
    • Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
  8. Dell Optiplex SX280 Motherboard Replacement: 手順 8、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 8、 2の画像 2
    • Remove the rubber grommets from the base of the fan. A spudger may be useful.
  9. Dell Optiplex SX280 Motherboard Replacement: 手順 9、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 9、 2の画像 2
    • Press on the blue release tab and pull the upper fan out of the computer.
  10. Dell Optiplex SX280 Motherboard Replacement, Lower Fan: 手順 10、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement, Lower Fan: 手順 10、 2の画像 2
    • Remove the power supply that connects the lower fan to the motherboard, distinguished by it's black, red, green and yellow wires.
    • Make sure to press on the release tab while removing the power connector.
  11. Dell Optiplex SX280 Motherboard Replacement: 手順 11、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 11、 2の画像 2
  12. Dell Optiplex SX280 Motherboard Replacement: 手順 12、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 12、 2の画像 2
    • Press on the blue release tab and remove the fan.
  13. Dell Optiplex SX280 Motherboard Replacement, RAM: 手順 13、 1の画像 1
    • The RAM are the two green cards in the corner of the computer.
    • At each end of the card, there are two white clips securing the RAM to the Motherboard.
  14. Dell Optiplex SX280 Motherboard Replacement: 手順 14、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 14、 2の画像 2
    • Push down both white clips with your thumbs until you hear a click.
    • The RAM cards can now be removed.
  15. Dell Optiplex SX280 Motherboard Replacement, Hard Drive: 手順 15、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement, Hard Drive: 手順 15、 2の画像 2
    • Unplug the blue cable that connects the hard drive to the motherboard.
  16. Dell Optiplex SX280 Motherboard Replacement: 手順 16、 1の画像 1
    • Unplug the power supply, distinguished by its red and yellow wires.
  17. Dell Optiplex SX280 Motherboard Replacement: 手順 17、 1の画像 1
    • Squeeze the release tabs on either side of the hard drive.
    • Then slide the hard drive out of the computer while squeezing the tabs.
  18. Dell Optiplex SX280 Motherboard Replacement, Motherboard: 手順 18、 1の画像 1
    • Unplug the cable that connects the hard drive to the Motherboard.
  19. Dell Optiplex SX280 Motherboard Replacement: 手順 19、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 19、 2の画像 2
    • Press on the release tab and remove the motherboard speaker which is attached to the side of the tower.
  20. Dell Optiplex SX280 Motherboard Replacement: 手順 20、 1の画像 1
    • Unplug the power cable attached to the motherboard speaker.
    • Make sure to press on the release tab while removing the power cable.
  21. Dell Optiplex SX280 Motherboard Replacement: 手順 21、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 21、 2の画像 2
    • Remove four screws located at the back of the computer tower.
  22. Dell Optiplex SX280 Motherboard Replacement: 手順 22、 1の画像 1
    • Carefully detach the motherboard from the computer case.
  23. Dell Optiplex SX280 Motherboard Replacement: 手順 23、 1の画像 1
    • Lift the motherboard from the rest of the computer case.
  24. Dell Optiplex SX280 Motherboard Replacement: 手順 24、 1の画像 1
    • Unplug the cable that powers the hard drive, which has orange, red and yellow wires.
    • Make sure to press the release tab while removing the cable.
  25. Dell Optiplex SX280 Motherboard Replacement: 手順 25、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 25、 2の画像 2
    • Unplug the cable that powers the emergency shut off, distinguished by its red wires.
    • Make sure to press on the release tab while removing the emergency shut off.
  26. Dell Optiplex SX280 Motherboard Replacement: 手順 26、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 26、 2の画像 2
    • Remove two screws from the Hard Drive Stand.
  27. Dell Optiplex SX280 Motherboard Replacement: 手順 27、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 27、 2の画像 2
    • Slide the Hard Drive Stand to left side.
    • Remove the stand from the rest of the rear panel.
  28. Dell Optiplex SX280 Motherboard Replacement: 手順 28、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 28、 2の画像 2
    • Remove the studs that support the Hard Drive Stand from the motherboard.
    • The studs can be removed by hand.
  29. Dell Optiplex SX280 Motherboard Replacement: 手順 29、 3の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 29、 3の画像 2 Dell Optiplex SX280 Motherboard Replacement: 手順 29、 3の画像 3
    • Remove the four screws located on heat sink stand.
    • The heat sink stand can now be lifted from the motherboard.
  30. Dell Optiplex SX280 Motherboard Replacement: 手順 30、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 30、 2の画像 2
    • Remove the four screws holding the motherboard to the rear computer panel.
  31. Dell Optiplex SX280 Motherboard Replacement: 手順 31、 2の画像 1 Dell Optiplex SX280 Motherboard Replacement: 手順 31、 2の画像 2
    • The motherboard can now be removed from the remaining panel.
終わりに
11 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Tom
メンバー登録日: 10/04/10
841 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S22G4
4 メンバー
26のガイドは作成済み
2 件のコメント
Good job. Thanks for sharing, friend.
Angel Peguero - 返信
Great guide! I got stuck at the Mobo tray, I knew the black screws were involved but couldn't get it with out help. Thanks!
Fans can be removed with board tray, otherwise they're getting pulled off their rubber isolating feet. Once out with the mobo, the fans slide off the board tray with their plastic shoes attached.
purchases - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 15
今までの合計 19,168
