はじめに
Remove the Lower Fan from the computer tower.
パーツ
パーツは必要ありません。
  1. Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Lay the computer on its side; you will see a blue knob. Turn this knob 90 deg clockwise.
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Slide the panel case forward about 1/2 inch while knob is turned. Lift panel case off computer.
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Remove the large blue cover from the computer. There are no screws or tabs holding it in place. Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
    • Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
  6. Remove the power supply that connects the lower fan to the motherboard, distinguished by it's black, red, green and yellow wires.
    • Remove the power supply that connects the lower fan to the motherboard, distinguished by it's black, red, green and yellow wires.
    • Make sure to press on the release tab while removing the power supply.
  7. Remove the rubber grommets from the base of the fan. A spudger may be useful. Remove the rubber grommets from the base of the fan. A spudger may be useful.
    • Remove the rubber grommets from the base of the fan. A spudger may be useful.
  8. Press on the blue release tab and remove the fan. Press on the blue release tab and remove the fan.
    • Press on the blue release tab and remove the fan.
まとめ
2 の人々がこのガイドを完成させました。
Tom
メンバー登録日: 2010年10月04日
799 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S22G4
4 メンバー
13のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 3,891
