メインコンテンツにスキップ
Dell Optiplex SX280 Battery Replacement
必要な工具と部品
  1. Dell Optiplex SX280 Battery Replacement, Panel Cover: 手順 1、 1の画像 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Battery Replacement: 手順 2、 2の画像 1 Dell Optiplex SX280 Battery Replacement: 手順 2、 2の画像 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Battery Replacement: 手順 3、 2の画像 1 Dell Optiplex SX280 Battery Replacement: 手順 3、 2の画像 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Battery Replacement, Hard Drive: 手順 4、 2の画像 1 Dell Optiplex SX280 Battery Replacement, Hard Drive: 手順 4、 2の画像 2
    • Unplug the blue cable that connects the hard drive to the motherboard.
  5. Dell Optiplex SX280 Battery Replacement: 手順 5、 2の画像 1 Dell Optiplex SX280 Battery Replacement: 手順 5、 2の画像 2
    • Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
  6. Dell Optiplex SX280 Battery Replacement: 手順 6、 1の画像 1
    • Squeeze the release tabs on either side of the hard drive.
  7. Dell Optiplex SX280 Battery Replacement: 手順 7、 2の画像 1 Dell Optiplex SX280 Battery Replacement: 手順 7、 2の画像 2
    • Slide the Hard Drive out while squeezing the tabs.
  8. Dell Optiplex SX280 Battery Replacement, Battery: 手順 8、 1の画像 1
    • Under the hard drive, there is a circular, silver battery connected to the motherboard.
    • Use a spudger to gently pry the battery from the motherboard.
  9. Dell Optiplex SX280 Battery Replacement: 手順 9、 1の画像 1
    • Lift the battery out of the motherboard.
  10. Dell Optiplex SX280 Battery Replacement: 手順 10、 3の画像 1 Dell Optiplex SX280 Battery Replacement: 手順 10、 3の画像 2 Dell Optiplex SX280 Battery Replacement: 手順 10、 3の画像 3
    • Upon replacement, simply push the battery into the motherboard.
終わりに
10 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Tom
メンバー登録日: 10/04/10
850 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S22G4
4 メンバー
26のガイドは作成済み
1件のガイドコメント
that particular battery holder looked hard to get out- no pop out lever, thought i’d break it gouging it out!
neverts “itchytastyurr” ennud - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 12
今までの合計 11,923
