メインコンテンツにスキップ
Dell Optiplex GX620 Power Supply Replacement
必要な工具と部品
  1. Dell Optiplex GX620 Power Supply Replacement, How to unplug and discharge before repair: 手順 1、 2の画像 1 Dell Optiplex GX620 Power Supply Replacement, How to unplug and discharge before repair: 手順 1、 2の画像 2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Power Supply Replacement: 手順 2、 2の画像 1 Dell Optiplex GX620 Power Supply Replacement: 手順 2、 2の画像 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Power Supply Replacement, Dell Optiplex GX620 Side Panel Disassembly: 手順 3、 1の画像 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Power Supply Replacement, Disconnect cables: 手順 4、 3の画像 1 Dell Optiplex GX620 Power Supply Replacement, Disconnect cables: 手順 4、 3の画像 2 Dell Optiplex GX620 Power Supply Replacement, Disconnect cables: 手順 4、 3の画像 3
    • Gently disconnect the power cables from the motherboard and drives.
  5. Dell Optiplex GX620 Power Supply Replacement, Remove the screws: 手順 5、 1の画像 1
    • Remove the four screws that attach the power supply on the back of the chassis.
    • Do not remove any screws that are not highlighted in red.
  6. Dell Optiplex GX620 Power Supply Replacement, Press the release button: 手順 6、 1の画像 1
    • Press the blue release button. This is located on the floor of the computer chassis right in front of the power supply.
  7. Dell Optiplex GX620 Power Supply Replacement, Remove the power supply: 手順 7、 1の画像 1
    • Remove the unconnected power supply by sliding it towards the front of the computer. Next, lift it up out of the chassis.
終わりに
10 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Kristina
メンバー登録日: 09/03/14
210 ポイント
7のガイドは作成済み
チーム
Pasco Hernando, Team 5-1, Prince Fall 2014 Pasco Hernando, Team 5-1, Prince Fall 2014人のメンバー
PHSC-PRINCE-F14S5G1
10 メンバー
15のガイドは作成済み
3 Guide Comments
Thanks, I followed the instructions, the replacement of the power supply unit was more simple than I expected
George
geotech78 - 返信
i replaced that but not repair this
Muhammad Qasim - 返信
At post Madasanal TQ disk bijapur
sidaray - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 37
今までの合計 7,292
