メインコンテンツにスキップ
Dell Optiplex GX620 Optical Drive Replacement
必要な工具と部品
  1. Dell Optiplex GX620 Optical Drive Replacement, How to unplug and discharge before repair: 手順 1、 2の画像 1 Dell Optiplex GX620 Optical Drive Replacement, How to unplug and discharge before repair: 手順 1、 2の画像 2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Optical Drive Replacement: 手順 2、 2の画像 1 Dell Optiplex GX620 Optical Drive Replacement: 手順 2、 2の画像 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Optical Drive Replacement, Dell Optiplex GX620 Side Panel Disassembly: 手順 3、 1の画像 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Optical Drive Replacement, Remove the drive panel: 手順 4、 1の画像 1
    • Slide the blue latch downward until the panel can be removed from it's hinges.
  5. Dell Optiplex GX620 Optical Drive Replacement, Disconnect the cables: 手順 5、 1の画像 1
    • Gently remove the CD/DVD and power cables from the back of the optical drive
  6. Dell Optiplex GX620 Optical Drive Replacement, Remove the screws: 手順 6、 1の画像 1
    • Using a Phillips #1 screwdriver, remove the screw connecting the optical drive to the drive bay.
  7. Dell Optiplex GX620 Optical Drive Replacement, Remove the optical drive: 手順 7、 2の画像 1 Dell Optiplex GX620 Optical Drive Replacement, Remove the optical drive: 手順 7、 2の画像 2
    • To remove the optical drive from the drive bay, slide the drive towards the front of the computer.
終わりに
作成者
5人の作成者と共同で作成されました。
Kristina
メンバー登録日: 09/03/14
210 ポイント
7のガイドは作成済み
チーム
Pasco Hernando, Team 5-1, Prince Fall 2014 Pasco Hernando, Team 5-1, Prince Fall 2014人のメンバー
PHSC-PRINCE-F14S5G1
10 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 3,089
