メインコンテンツにスキップ
Dell Optiplex GX620 Motherboard Replacement
必要な工具と部品
  1. Dell Optiplex GX620 Motherboard  Replacement, How to unplug and discharge before repair: 手順 1、 2の画像 1 Dell Optiplex GX620 Motherboard  Replacement, How to unplug and discharge before repair: 手順 1、 2の画像 2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Motherboard  Replacement: 手順 2、 2の画像 1 Dell Optiplex GX620 Motherboard  Replacement: 手順 2、 2の画像 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Motherboard  Replacement, Dell Optiplex GX620 Side Panel Disassembly: 手順 3、 1の画像 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Motherboard  Replacement, Now unplug your hard drives power and data cables.: 手順 4、 3の画像 1 Dell Optiplex GX620 Motherboard  Replacement, Now unplug your hard drives power and data cables.: 手順 4、 3の画像 2 Dell Optiplex GX620 Motherboard  Replacement, Now unplug your hard drives power and data cables.: 手順 4、 3の画像 3
    • Move the cables out of your way.
    • SATA Power
    • SATA Data
  5. Dell Optiplex GX620 Motherboard  Replacement, Unplug your floppy drive on the motherboard and the drive.: 手順 5、 3の画像 1 Dell Optiplex GX620 Motherboard  Replacement, Unplug your floppy drive on the motherboard and the drive.: 手順 5、 3の画像 2 Dell Optiplex GX620 Motherboard  Replacement, Unplug your floppy drive on the motherboard and the drive.: 手順 5、 3の画像 3
    • Unplug the power cable
    • Unplug the data cable
  6. Dell Optiplex GX620 Motherboard  Replacement, Disconnect CPU fan.: 手順 6、 2の画像 1 Dell Optiplex GX620 Motherboard  Replacement, Disconnect CPU fan.: 手順 6、 2の画像 2
    • Unplug the fan that is on the motherboard.
  7. Dell Optiplex GX620 Motherboard  Replacement: 手順 7、 2の画像 1 Dell Optiplex GX620 Motherboard  Replacement: 手順 7、 2の画像 2
    • There is two Phillips #2 screws that need to be removed.
    • The two screws have springs that keep them there.
  8. Dell Optiplex GX620 Motherboard  Replacement, New it’s time to remove the  heat sink.: 手順 8、 3の画像 1 Dell Optiplex GX620 Motherboard  Replacement, New it’s time to remove the  heat sink.: 手順 8、 3の画像 2 Dell Optiplex GX620 Motherboard  Replacement, New it’s time to remove the  heat sink.: 手順 8、 3の画像 3
    • Lift the heat sink.
  9. Dell Optiplex GX620 Motherboard  Replacement, CPU removal.: 手順 9、 3の画像 1 Dell Optiplex GX620 Motherboard  Replacement, CPU removal.: 手順 9、 3の画像 2 Dell Optiplex GX620 Motherboard  Replacement, CPU removal.: 手順 9、 3の画像 3
    • Push and release tap on it. And then take the CPU out.
    • Remember to put new thermal paste on the CPU.
  10. Dell Optiplex GX620 Motherboard  Replacement, Remove the ram: 手順 10、 2の画像 1 Dell Optiplex GX620 Motherboard  Replacement, Remove the ram: 手順 10、 2の画像 2
    • Push the tabs down.
    • Pull the cards out.
  11. Dell Optiplex GX620 Motherboard  Replacement, Remove the DVD cable: 手順 11、 3の画像 1 Dell Optiplex GX620 Motherboard  Replacement, Remove the DVD cable: 手順 11、 3の画像 2 Dell Optiplex GX620 Motherboard  Replacement, Remove the DVD cable: 手順 11、 3の画像 3
    • Pull the two cables from the DVD drive off.
  12. Dell Optiplex GX620 Motherboard  Replacement: 手順 12、 2の画像 1 Dell Optiplex GX620 Motherboard  Replacement: 手順 12、 2の画像 2
    • Pull the power cable from the DVD drive off.
  13. Dell Optiplex GX620 Motherboard  Replacement, Remove the CPU power: 手順 13、 1の画像 1
    • Pull the CPU power cable off.
  14. Dell Optiplex GX620 Motherboard  Replacement, Remove the three cables: 手順 14、 2の画像 1 Dell Optiplex GX620 Motherboard  Replacement, Remove the three cables: 手順 14、 2の画像 2
    • Pull the three cables off.
  15. Dell Optiplex GX620 Motherboard  Replacement, Remove the graphics card: 手順 15、 3の画像 1 Dell Optiplex GX620 Motherboard  Replacement, Remove the graphics card: 手順 15、 3の画像 2 Dell Optiplex GX620 Motherboard  Replacement, Remove the graphics card: 手順 15、 3の画像 3
    • Push the tab to releases the latch.
    • Push the tab and pull the graphics card out.
  16. Dell Optiplex GX620 Motherboard  Replacement, Remove the motherboard screws: 手順 16、 2の画像 1 Dell Optiplex GX620 Motherboard  Replacement, Remove the motherboard screws: 手順 16、 2の画像 2
    • Remove the six Philips #2 screws.
    • Remove the two green Philips #2 screws.
  17. Dell Optiplex GX620 Motherboard  Replacement, Remove the motherboard: 手順 17、 3の画像 1 Dell Optiplex GX620 Motherboard  Replacement, Remove the motherboard: 手順 17、 3の画像 2 Dell Optiplex GX620 Motherboard  Replacement, Remove the motherboard: 手順 17、 3の画像 3
    • Gently pull the motherboard out.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Padraic Hoselton
メンバー登録日: 08/22/17
4,270 ポイント
12のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
327 メンバー
1,699のガイドは作成済み
コメント 1 件
Pawer on of reset button connection kese kre or motherboard per
Deepak Kumar - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 39
今までの合計 3,338
