メインコンテンツにスキップ
Dell Optiplex GX620 Front panel Replacement
必要な工具と部品
  1. Dell Optiplex GX620 Front panel Replacement, How to unplug and discharge before repair: 手順 1、 2の画像 1 Dell Optiplex GX620 Front panel Replacement, How to unplug and discharge before repair: 手順 1、 2の画像 2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Front panel Replacement: 手順 2、 2の画像 1 Dell Optiplex GX620 Front panel Replacement: 手順 2、 2の画像 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Front panel Replacement, Dell Optiplex GX620 Side Panel Disassembly: 手順 3、 1の画像 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Front panel Replacement, Unplug your hard drive.: 手順 4、 3の画像 1 Dell Optiplex GX620 Front panel Replacement, Unplug your hard drive.: 手順 4、 3の画像 2 Dell Optiplex GX620 Front panel Replacement, Unplug your hard drive.: 手順 4、 3の画像 3
    • Remove the SATA power and data cables.
    • SATA Power
    • SATA Data
  5. Dell Optiplex GX620 Front panel Replacement, Unplug your floppy drive.: 手順 5、 3の画像 1 Dell Optiplex GX620 Front panel Replacement, Unplug your floppy drive.: 手順 5、 3の画像 2 Dell Optiplex GX620 Front panel Replacement, Unplug your floppy drive.: 手順 5、 3の画像 3
    • Unplug the power and data cables.
  6. Dell Optiplex GX620 Front panel Replacement, Unplug the fan.: 手順 6、 2の画像 1 Dell Optiplex GX620 Front panel Replacement, Unplug the fan.: 手順 6、 2の画像 2
    • Unplug the fan.
  7. Dell Optiplex GX620 Front panel Replacement: 手順 7、 2の画像 1 Dell Optiplex GX620 Front panel Replacement: 手順 7、 2の画像 2
    • Remove the two Phillips #2 screws.
  8. Dell Optiplex GX620 Front panel Replacement, Remove the heat sink.: 手順 8、 3の画像 1 Dell Optiplex GX620 Front panel Replacement, Remove the heat sink.: 手順 8、 3の画像 2 Dell Optiplex GX620 Front panel Replacement, Remove the heat sink.: 手順 8、 3の画像 3
    • Pull the heat sink up.
  9. Dell Optiplex GX620 Front panel Replacement: 手順 9、 3の画像 1 Dell Optiplex GX620 Front panel Replacement: 手順 9、 3の画像 2 Dell Optiplex GX620 Front panel Replacement: 手順 9、 3の画像 3
    • Pull the two tabs and pull it out.
    • This needs a lot of force to take it off.
  10. Dell Optiplex GX620 Front panel Replacement, Remove front panel: 手順 10、 2の画像 1 Dell Optiplex GX620 Front panel Replacement, Remove front panel: 手順 10、 2の画像 2
    • Remove the one Phillips #2.
    • Remove the Data cable.
    • Taking this cable off will brake some of the plastic thats locking it in. But you can still plug the cable back in.
  11. Dell Optiplex GX620 Front panel Replacement, Remove the last screw.: 手順 11、 2の画像 1 Dell Optiplex GX620 Front panel Replacement, Remove the last screw.: 手順 11、 2の画像 2
    • Remove the one Phillips #2 screw.
    • Now you can replace it with a new one.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Padraic Hoselton
メンバー登録日: 08/22/17
4,204 ポイント
12のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,516のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 1,536
