メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Optiplex GX620 CPU Replacement
必要な工具と部品
  1. Dell Optiplex GX620 CPU Replacement, How to unplug and discharge before repair: 手順 1、 2の画像 1 Dell Optiplex GX620 CPU Replacement, How to unplug and discharge before repair: 手順 1、 2の画像 2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 CPU Replacement: 手順 2、 2の画像 1 Dell Optiplex GX620 CPU Replacement: 手順 2、 2の画像 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 CPU Replacement, Dell Optiplex GX620 Side Panel Disassembly: 手順 3、 1の画像 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: 手順 4、 3の画像 1 Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: 手順 4、 3の画像 2 Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: 手順 4、 3の画像 3
    • Move the cables out of your way.
    • SATA Power
    • SATA Data
  5. Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: 手順 5、 3の画像 1 Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: 手順 5、 3の画像 2 Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: 手順 5、 3の画像 3
    • Unplug the power cable
    • Unplug the data cable
  6. Dell Optiplex GX620 CPU Replacement, Disconnect CPU fan.: 手順 6、 2の画像 1 Dell Optiplex GX620 CPU Replacement, Disconnect CPU fan.: 手順 6、 2の画像 2
    • Unplug the fan that is on the motherboard.
  7. Dell Optiplex GX620 CPU Replacement: 手順 7、 2の画像 1 Dell Optiplex GX620 CPU Replacement: 手順 7、 2の画像 2
    • There is two Phillips #2 screws that need to be removed.
    • The two screws have springs that keep them there.
  8. Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: 手順 8、 3の画像 1 Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: 手順 8、 3の画像 2 Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: 手順 8、 3の画像 3
    • Lift the heat sink.
  9. Dell Optiplex GX620 CPU Replacement, CPU removal.: 手順 9、 3の画像 1 Dell Optiplex GX620 CPU Replacement, CPU removal.: 手順 9、 3の画像 2 Dell Optiplex GX620 CPU Replacement, CPU removal.: 手順 9、 3の画像 3
    • Push and release tap on it. And then take the CPU out.
    • Remember to put new thermal paste on the CPU.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Padraic Hoselton
メンバー登録日: 08/22/17
4,339 ポイント
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 69
今までの合計 2,768
