メインコンテンツにスキップ
Dell Optiplex GX620 CMOS Battery Replacement
必要な工具と部品
  1. Dell Optiplex GX620 CMOS Battery Replacement, How to unplug and discharge before repair: 手順 1、 2の画像 1 Dell Optiplex GX620 CMOS Battery Replacement, How to unplug and discharge before repair: 手順 1、 2の画像 2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 CMOS Battery Replacement: 手順 2、 2の画像 1 Dell Optiplex GX620 CMOS Battery Replacement: 手順 2、 2の画像 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 CMOS Battery Replacement, Dell Optiplex GX620 Side Panel Disassembly: 手順 3、 1の画像 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 CMOS Battery Replacement, Removing the CMOS Battery: 手順 4、 1の画像 1
    • Insert a tool beside the battery and gently pry the battery out.
    • Using a screwdriver to pry open anything can harm your device. Instead, use a spudger or a plastic opening tool.
終わりに
To reassemble your device, follow these instructions in reverse order. Make sure you place the battery with the flat (positive) side facing up.
9 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Kristina
メンバー登録日: 09/03/14
210 ポイント
7のガイドは作成済み
チーム
Pasco Hernando, Team 5-1, Prince Fall 2014 Pasco Hernando, Team 5-1, Prince Fall 2014人のメンバー
PHSC-PRINCE-F14S5G1
10 メンバー
15のガイドは作成済み
2 件のコメント
Thank you for this. It gave me the courage to do the job, and told me how. I'm very, very grateful.
Richard Samuel - 返信
Shouldn't the battery be listed in the parts? Squinting at the photo, it seems to be a CR2032?
vcayenne - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 75
今までの合計 16,086
