メインコンテンツにスキップ
Dell Optiplex 745 Ultra Small Form Factor RAM Replacement
必要な工具と部品
  1. Dell Optiplex 745 Ultra Small Form Factor RAM Replacement, Side Panel: 手順 1、 1の画像 1
    • Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex 745 Ultra Small Form Factor RAM Replacement: 手順 2、 1の画像 1
    • Lay the computer on its side; you will see a blue knob.
    • Turn said knob 90 degrees counter clockwise.
  3. Dell Optiplex 745 Ultra Small Form Factor RAM Replacement: 手順 3、 1の画像 1
    • While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
  4. Dell Optiplex 745 Ultra Small Form Factor RAM Replacement, Hard Drive: 手順 4、 2の画像 1 Dell Optiplex 745 Ultra Small Form Factor RAM Replacement, Hard Drive: 手順 4、 2の画像 2
    • Ground yourself to avoid static from damaging any components. Either use a wrist strap and antistatic mat, or touch the metal computer case every few minutes.
    • Find the power and data cables connected to the hard drive, press down on the metal tab and carefully remove them.
  5. Dell Optiplex 745 Ultra Small Form Factor RAM Replacement: 手順 5、 2の画像 1 Dell Optiplex 745 Ultra Small Form Factor RAM Replacement: 手順 5、 2の画像 2
    • Locate the blue tabs shown on the left and right of the hard disk drive
    • Squeeze both tabs and slide the hard disk drive towards you, then lift the drive out of the cage.
  6. Dell Optiplex 745 Ultra Small Form Factor RAM Replacement, RAM: 手順 6、 1の画像 1
    • Press down on the two white tabs on either side of the memory module; the RAM will pop out.
    • Be sure you are grounded to avoid electrostatic discharge, and place your memory modules in an anti-static bag.
    • Make sure the notch in the RAM lines up with the notch in the slot. It should enter the slot with minimal force. If it does not enter the slot, check that you have the RAM lined up properly.
終わりに
作成者
7人の作成者と共同で作成されました。
donnavon
メンバー登録日: 09/02/14
707 ポイント
7のガイドは作成済み
チーム
Pasco Hernando, Team 1-1, Prince Fall 2014 Pasco Hernando, Team 1-1, Prince Fall 2014人のメンバー
PHSC-PRINCE-F14S1G1
11 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 1,773
