メインコンテンツにスキップ
Dell Optiplex 745 Ultra Small Form Factor CPU Replacement
必要な工具と部品
  1. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, Side Panel: 手順 1、 1の画像 1
    • Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 手順 2、 1の画像 1
    • Lay the computer on its side; you will see a blue knob.
    • Turn said knob 90 degrees counter clockwise.
  3. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 手順 3、 1の画像 1
    • While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
  4. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU Heat Sink: 手順 4、 2の画像 1 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU Heat Sink: 手順 4、 2の画像 2
    • Remove the blue shield by sliding it straight upwards.
  5. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 手順 5、 3の画像 1 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 手順 5、 3の画像 2 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 手順 5、 3の画像 3
    • Pull back on the tab nearest to the front case fan.
    • Slide the CPU heat sink from under the clip and pull upward.
    • You may need to twist the CPU heat sink side to side to free it from the thermal paste.
  6. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU: 手順 6、 2の画像 1 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU: 手順 6、 2の画像 2
    • Ground yourself before removing any internal components.
    • Push release lever down slightly and away from CPU.
  7. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 手順 7、 2の画像 1 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 手順 7、 2の画像 2
    • Lift and rotate processor cover off of CPU.
    • Processor cover will remain attached.
  8. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 手順 8、 1の画像 1
    • Using two fingers holding the sides, lift the CPU from the socket.
    • Do not touch the underside of the CPU or any of the pins.
    • When replacing the CPU, do not use excessive force.
    • Ensure to use the alignment-notches on the new CPU, when replacing.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
donnavon
メンバー登録日: 09/02/14
707 ポイント
7のガイドは作成済み
チーム
Pasco Hernando, Team 1-1, Prince Fall 2014 Pasco Hernando, Team 1-1, Prince Fall 2014人のメンバー
PHSC-PRINCE-F14S1G1
11 メンバー
14のガイドは作成済み
コメント 1 件
What Cpu does it use?
Jazelle Estrada - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 18
今までの合計 2,161
