メインコンテンツにスキップ
Dell Optiplex 745 Small Form Factor Motherboard Replacement
必要な工具と部品
  1. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Opening the case: 手順 1、 2の画像 1 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Opening the case: 手順 1、 2の画像 2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Motherboard Replacement: 手順 2、 2の画像 1 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 手順 2、 2の画像 2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: 手順 3、 3の画像 1 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: 手順 3、 3の画像 2 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: 手順 3、 3の画像 3
    • Disconnect all of the cords that are connected to the motherboard.
    • Press in the lever on the side of the male end, and then pull out.
    • Pull cord straight out.
    • Disconnect the front plate (USB and audio output) from the motherboard.
    • Some of the cords in the pictures are missing due to the condition of our device when creating this guide.
  4. Dell Optiplex 745 Small Form Factor Motherboard Replacement: 手順 4、 3の画像 1 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 手順 4、 3の画像 2 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 手順 4、 3の画像 3
    • Remove the graphics card.
    • Lift the blue latch on the fat end of the graphics card.
    • Pull the blue lever on the skinny end of the graphics card toward the power supply.
    • Pull out one end of the card at a time.
  5. Dell Optiplex 745 Small Form Factor Motherboard Replacement: 手順 5、 3の画像 1 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 手順 5、 3の画像 2 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 手順 5、 3の画像 3
    • Remove the heat sink.
    • Unscrew the (2) two screws using a Phillips #2 screwdriver and lift out the heat sink.
  6. Dell Optiplex 745 Small Form Factor Motherboard Replacement: 手順 6、 3の画像 1 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 手順 6、 3の画像 2 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 手順 6、 3の画像 3
    • Remove the (5) five 6mm Phillips #2 screws from the motherboard.
    • Remove the (2) two 17mm Phillips #2 screws from the mount for the heat sink.
  7. Dell Optiplex 745 Small Form Factor Motherboard Replacement: 手順 7、 3の画像 1 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 手順 7、 3の画像 2 Dell Optiplex 745 Small Form Factor Motherboard Replacement: 手順 7、 3の画像 3
    • Remove the back plate by lifting straight out by the blue latch that secures the graphics card.
    • Pull the end of the motherboard closest to the back of the computer away from the static back plate.
    • Lift this end away and out of the case.
終わりに
7 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Alexander Rosner
メンバー登録日: 10/03/17
291 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S5-G5, Walkup Fall 2017 USF Tampa, Team S5-G5, Walkup Fall 2017人のメンバー
USFT-WALKUP-F17S5G5
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 31
今までの合計 1,749
