メインコンテンツにスキップ
Dell Optiplex 745 Small Form Factor Hard Drive Replacement
  1. Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Opening the case: 手順 1、 2の画像 1 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Opening the case: 手順 1、 2の画像 2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Hard Drive Replacement: 手順 2、 2の画像 1 Dell Optiplex 745 Small Form Factor Hard Drive Replacement: 手順 2、 2の画像 2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Disconnecting the cables: 手順 3、 2の画像 1 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Disconnecting the cables: 手順 3、 2の画像 2
    • Pull out both sets of cables from the side of the optical drive.
    • Both cables are plugged into the drive right next to each other.
  4. Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Removing the optical drive: 手順 4、 2の画像 1 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Removing the optical drive: 手順 4、 2の画像 2
    • Pull the tab up holding the optical drive in place.
    • Slide the optical drive out.
  5. Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Remove the tray under the optical drive: 手順 5、 3の画像 1 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Remove the tray under the optical drive: 手順 5、 3の画像 2 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Remove the tray under the optical drive: 手順 5、 3の画像 3
    • Rotate the computer 180 degrees.
    • Pull the metal tab up.
    • Pull the tray away from the case.
  6. Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Remove the hard drive case: 手順 6、 3の画像 1 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Remove the hard drive case: 手順 6、 3の画像 2 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Remove the hard drive case: 手順 6、 3の画像 3
    • Pinch the 2 small blue tabs towards each other.
    • Push the large blue tab into the hard drive and push the hard drive away from the tower wall.
    • Lift the hard drive from the case after it comes loose.
  7. Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Remove the wires: 手順 7、 2の画像 1 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Remove the wires: 手順 7、 2の画像 2
    • Pull out both bundles of wires connected to the hard drive.
    • Flip the hard drive so that the blue case is facing down, and the marked tabs are facing toward you.
  8. Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Separate the hard drive and case.: 手順 8、 3の画像 1 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Separate the hard drive and case.: 手順 8、 3の画像 2 Dell Optiplex 745 Small Form Factor Hard Drive Replacement, Separate the hard drive and case.: 手順 8、 3の画像 3
    • Pull the 2 blue tabs away from the hard drive and then pull the hard drive case down.
終わりに
19 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Rebecca Harrison
メンバー登録日: 09/29/14
524 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 13-10, Forte Fall 2014 Cal Poly, Team 13-10, Forte Fall 2014人のメンバー
CPSU-FORTE-F14S13G10
6 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 66
今までの合計 9,501
