必要な工具と部品
Disconnect the ATX power cable to the motherboard.
Disconnect the P4 12V(4x2) power cable from the motherboard.
With the motherboard out of the tray, let your soldering gear warm up and get a desoldering braid.
Desoldering can damage motherboards, so first practice on a board you don't need. Use a 40-50W soldering iron with a chisel tip and 0.080" wide desoldering braid. Also helpful are rosin flux and 60/40 tin/lead solder, in case all the solder doesn't come out. Wiggle desoldered leads to verify they're free, and never pull on any that aren't.
3 の人々がこのガイドを完成させました。
cool de faires des sites comme ca :)
baptiste Prando - 返信
Excellent - Only comment - do the the green brackets come with a new hard drive or should I leave them inside the case for the next owner - Removing to donate to recycling
sheila_jones - 返信
I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
Elvis 1357 - 返信
Also, want to add another HD....but, there are no cables at all?
Elvis 1357 - 返信
