必要な工具と部品
Push out on the cream colored tabs on each side of each RAM module until it pops up and out of its slot and remove the RAM.
salope pute bite
tg beaufion travail
Albert reste polie
tg beaufillons
jvai tenculer baltringue va
Cui Cui !!!!
zamaaaaaaaaan tu fait quoi la
coco arrete tes blocus
BENJUX ENTHE FLUX arret t’es conérie
Abder la salope
Sdk mes bébé la
Faux curly mm
c’est un ouff l’acteur
c’est un oufff Ritchie
Disconnect the ATX power cable to the motherboard.
Disconnect the P4 12V(4x2) power cable from the motherboard.
15 の人々がこのガイドを完成させました。
4 件のコメント
Mines stuck for some reason I almost bent the frame from pushing the ports in while lifting and pulling the tray tab away
make sure you doing it the correct side!
muy bueno gracias bro
Mine did not have the big green fan in back. Rest of the disassembly was similar, until I got to actually removing the PCB from the metal back plate. This says to simply slide it forward while holding the plate in place. Yeah… well, in theory. It actually took a fair amount of gentle prying to get the PCB to slide forward. The key is the little metal grounding clips in the corners. The fingers do not actually present much pressure. However, the vertical metal to which they press is an overhang. So the trick is to gently FORCE the PCB forward at each rear corner until such time as the overhang no longer exists. At this point the vertical metal tab will be full back against their respective slots. The PCB will simply lift out then.
cool de faires des sites comme ca :)
baptiste Prando - 返信
Excellent - Only comment - do the the green brackets come with a new hard drive or should I leave them inside the case for the next owner - Removing to donate to recycling
sheila_jones - 返信
I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
Elvis 1357 - 返信
Also, want to add another HD....but, there are no cables at all?
Elvis 1357 - 返信
