メインコンテンツにスキップ
  1. Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you. Push the  oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  3. Identify the Hard Drive in the case. If there is more than one hard drive installed the process is the same for each hard drive. Remove the power cable from the hard drive by squeezing the side tabs in and pulling gently.
    • Identify the Hard Drive in the case.
    • If there is more than one hard drive installed the process is the same for each hard drive.
    • Remove the power cable from the hard drive by squeezing the side tabs in and pulling gently.
    • Remove the IDE cable from the hard drive by gently pulling the ribbon cable out.
  4. Pinch the two green tabs inwards to release the hard drive and lift it out.
    • Pinch the two green tabs inwards to release the hard drive and lift it out.
まとめ
4 の人々がこのガイドを完成させました。
Kevin Schapansky
メンバー登録日: 2010年10月05日
1,199 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010人のメンバー
CPSU-AMIDO-F10S4G48
4 メンバー
18のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 41
今までの合計 16,287
