はじめに
This guide was created to aid someone who would need to replace the memory board for the Dell Optiplex FX 170. Someone may need to replace the memory board if it is not working correctly or has failed. This is an easy component to replace with no hazards. One should, however, be familiar with electro-static discharge.
必要な工具と部品
Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
もう少しです!
終わりに
