はじめに
This guide was created to aid someone who would need to replace the memory board for the Dell Optiplex FX 170. Someone may need to replace the memory board if it is not working correctly or has failed. This is an easy component to replace with no hazards. One should, however, be familiar with electro-static discharge.
パーツ
パーツは必要ありません。
  1. With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • Pull the base stand straight up from the device.
  2. Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device. Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
    • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located. Use care to not apply excessive force that could damage retaining clips while running the spudger along the case. Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
    • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
    • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
  5. Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions. Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
    • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
  6. Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
    • Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
まとめ
Ashley Hansen
メンバー登録日: 2015年01月13日
219 ポイント
2のガイドは作成済み
チーム
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 797
