はじめに
The Heat Sink is the metal part with fins that is mounted on top of the motherboard.
必要な工具と部品
Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
To remove the battery, pull up on the connector that is plugged into the motherboard.
On the back side of the motherboard, use the tweezers to squeeze the four protruding clips. These should be in the same position as the four black buttons recessed into the heat sink (when viewed from the front).
3 の人々がこのガイドを完成させました。
