はじめに
If you have issues with your computer overheating, generating loud noises, or crashing frequently, it may have a problem with your CPU fan.
The CPU cooling fan prevents your computer from overheating and slowing down. Replacing your PC's old fan will help prolong the lifespans of your CPU and Dell OptiPlex 9010.
Follow this guide if you need to replace the CPU fan of your Dell OptiPlex 9010.
Before you begin, turn off your computer and unplug it from the outlet.
必要な工具と部品
Place the PC on a flat surface.
Turn the PC over so that the panel side faces upward.
You have successfully replaced the CPU Fan of your Dell Optiplex 9010!
ある他の人がこのガイドを完成しました。
