メインコンテンツにスキップ
Dell OptiPlex 3070 Micro-PC Hard Drive Replacement
必要な工具と部品
  1. Dell OptiPlex 3070 Micro-PC Hard Drive Replacement, Hard Drive: 手順 1、 3の画像 1 Dell OptiPlex 3070 Micro-PC Hard Drive Replacement, Hard Drive: 手順 1、 3の画像 2 Dell OptiPlex 3070 Micro-PC Hard Drive Replacement, Hard Drive: 手順 1、 3の画像 3
    • Prior to beginning this repair, power off the PC and remove all the cables, (including the power cable), to avoid damaging your device.
    • Use the Phillips #00 screwdriver to remove the single screw securing the case.
    • Slide the case horizontally away from the screw.
    • Remove the back case.
  2. Dell OptiPlex 3070 Micro-PC Hard Drive Replacement: 手順 2、 3の画像 1 Dell OptiPlex 3070 Micro-PC Hard Drive Replacement: 手順 2、 3の画像 2 Dell OptiPlex 3070 Micro-PC Hard Drive Replacement: 手順 2、 3の画像 3
    • Unlock and remove the hard drive from the connector.
    • Push the two tabs on the hard drive caddy and slide it away from the connector.
    • Once unlocked, remove the hard drive from the main board.
  3. Dell OptiPlex 3070 Micro-PC Hard Drive Replacement: 手順 3、 3の画像 1 Dell OptiPlex 3070 Micro-PC Hard Drive Replacement: 手順 3、 3の画像 2 Dell OptiPlex 3070 Micro-PC Hard Drive Replacement: 手順 3、 3の画像 3
    • Pull the case away from the four screws at each corner of the old hard drive to remove it from the case.
    • The hard drive should come out easily and you don't need screwdriver to remove it.
  4. Dell OptiPlex 3070 Micro-PC Hard Drive Replacement: 手順 4、 3の画像 1 Dell OptiPlex 3070 Micro-PC Hard Drive Replacement: 手順 4、 3の画像 2 Dell OptiPlex 3070 Micro-PC Hard Drive Replacement: 手順 4、 3の画像 3
    • Put your new hard drive in the case but match the SATA connection to the lines in the hard drive case so you know it is placed correctly.
    • Lock the four screws from case into the new hard drive.
    • No need to use a screwdriver as these screws are just a press and lock type.
  5. Dell OptiPlex 3070 Micro-PC Hard Drive Replacement: 手順 5、 3の画像 1 Dell OptiPlex 3070 Micro-PC Hard Drive Replacement: 手順 5、 3の画像 2 Dell OptiPlex 3070 Micro-PC Hard Drive Replacement: 手順 5、 3の画像 3
    • Flip the hard drive upside down.
    • Insert the hard drive into the connector.
    • Push the hard drive to lock it in.
    • You will hear a "click" sound when it locks.
  6. Dell OptiPlex 3070 Micro-PC Hard Drive Replacement: 手順 6、 3の画像 1 Dell OptiPlex 3070 Micro-PC Hard Drive Replacement: 手順 6、 3の画像 2 Dell OptiPlex 3070 Micro-PC Hard Drive Replacement: 手順 6、 3の画像 3
    • Put the cover back on and slide it with the steel tab towards the screw.
    • Make sure it is securely locked in. Check all the sides for any gaps.
    • Use the Phillips #00 screwdriver to replace the single screw and securely lock the cover.
終わりに
I hope the guide helped you to replace the hard-drive and you will now enjoy more space and faster PC. Thank you.
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Krushi Patel
メンバー登録日: 07/01/22
217 ポイント
1ガイドが承認済み
チーム
York University, Team M-21, Allen Summer 2022 York University, Team M-21, Allen Summer 2022人のメンバー
YORK-ALLEN-SU22SMG21
1 メンバー
1のガイドは作成済み
コメント 1 件
I love the simplicity yet concise feel of your guide. There are just enough steps to keep the reader motivated to go through with the repair, too many steps and your average reader would back off.
Your instructions were very clear and straight to the point and I appreciate the fact that you did not use any complex words to describe the steps so as to cater to an audience with little technical knowledge.
The photos were awesome as most of them had both your hands in them which gave a first person view perspective. On top of that, they were clear; without any motion blur . The pictures were also organized in a flip book style which further gives a sense of orientation to the reader. Nice use of markups on the pictures too!
Great work and well done.
Derek Anthony Hau Kau Fong - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 92
今までの合計 3,576
