メインコンテンツにスキップ
Dell Latitude X300 Palm Rest/Track Pad Replacement
必要な工具と部品
  1. Dell Latitude X300 Palm Rest/Track Pad Replacement, Battery: 手順 1、 1の画像 1
    • Before removing the battery from the laptop, make sure the power is off.
    • Push both battery locking clips outward at the same time.
  2. Dell Latitude X300 Palm Rest/Track Pad Replacement: 手順 2、 1の画像 1
    • Slide the battery out of the laptop.
  3. Dell Latitude X300 Palm Rest/Track Pad Replacement, Keyboard: 手順 3、 1の画像 1
    • Remove the four 4 mm Phillips #0 screws from the bottom of the laptop.
  4. Dell Latitude X300 Palm Rest/Track Pad Replacement: 手順 4、 2の画像 1 Dell Latitude X300 Palm Rest/Track Pad Replacement: 手順 4、 2の画像 2
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  5. Dell Latitude X300 Palm Rest/Track Pad Replacement: 手順 5、 1の画像 1
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  6. Dell Latitude X300 Palm Rest/Track Pad Replacement: 手順 6、 1の画像 1
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  7. Dell Latitude X300 Palm Rest/Track Pad Replacement: 手順 7、 1の画像 1
    • Remove the flexible ribbon from the ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
  8. Dell Latitude X300 Palm Rest/Track Pad Replacement, Palm Rest/Track Pad: 手順 8、 1の画像 1
    • Position the laptop so that the bottom is facing upward.
    • Remove the three 4 mm Phillips #0 screws holding the bottom of the palm rest.
  9. Dell Latitude X300 Palm Rest/Track Pad Replacement: 手順 9、 1の画像 1
    • Return the laptop to proper position and open the screen.
    • Remove the six 4 mm Phillips #0 screws holding in the palm rest.
  10. Dell Latitude X300 Palm Rest/Track Pad Replacement: 手順 10、 1の画像 1
    • Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
    • The ribbon attached to the track is short and extremely delicate. Use care when moving the palm rest.
  11. Dell Latitude X300 Palm Rest/Track Pad Replacement: 手順 11、 1の画像 1
    • Lift up on the small ZIF connector and remove the ribbon.
    • If the ribbon seems stuck, gently wiggle it to remove. Do not pull the ribbon with great force.
終わりに
作成者
8人の作成者と共同で作成されました。
Thomas Wong
メンバー登録日: 01/20/12
23 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 11-20, Maness Winter 2012 Cal Poly, Team 11-20, Maness Winter 2012人のメンバー
CPSU-MANESS-W12S11G20
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 859
