はじめに
Replacing a Latch on the Dell Latiude X300
パーツ
パーツは必要ありません。
  1. Make sure the power is off.
    • Make sure the power is off.
    • Remove the battery located on the bottom of the device by pushing in both clips.
  2. Remove rubber caps on each corner of the front screen with a pinch. Remove the 4 mm screws located on the front screen of the laptop.
    • Remove rubber caps on each corner of the front screen with a pinch.
    • Remove the 4 mm screws located on the front screen of the laptop.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Carefully, remove the screen casing using either your hands or a proper tool.
    • Carefully, remove the screen casing using either your hands or a proper tool.
    • The casing is very flimsy, so use extreme care.
  5. Remove the screws holding the latch in place.
    • Remove the screws holding the latch in place.
まとめ
2 の人々がこのガイドを完成させました。
Jacob
メンバー登録日: 2014年03月12日
9 ポイント
2のガイドは作成済み
チーム
University of Maryland, Team 6-1, Vijaybhaskar Spring 2014 University of Maryland, Team 6-1, Vijaybhaskar Spring 2014人のメンバー
UMD-VIJAYBHASKAR-S14S6G1
4 メンバー
2のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 171
