メインコンテンツにスキップ
Dell Latitude E7470 Motherboard Replacement
必要な工具と部品
  1. Dell Latitude E7470 Motherboard Replacement, RAM: 手順 1、 2の画像 1 Dell Latitude E7470 Motherboard Replacement, RAM: 手順 1、 2の画像 2
    • Grab the two clips beside the RAM stick and pull them outward. The RAM stick should release.
    • Remove the RAM from the device.
    • Repeat this for second RAM stick
  2. Dell Latitude E7470 Motherboard Replacement, Battery: 手順 2、 1の画像 1
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
  3. Dell Latitude E7470 Motherboard Replacement: 手順 3、 2の画像 1 Dell Latitude E7470 Motherboard Replacement: 手順 3、 2の画像 2
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
  4. Dell Latitude E7470 Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the battery from the laptop.
  5. Dell Latitude E7470 Motherboard Replacement, Fan and Heatsink: 手順 5、 2の画像 1 Dell Latitude E7470 Motherboard Replacement, Fan and Heatsink: 手順 5、 2の画像 2
    • After opening the backcase of the computer, remove the screws using the Phillips #0 screwdriver.
    • Unplug and remove the wire from the socket.
  6. Dell Latitude E7470 Motherboard Replacement: 手順 6、 1の画像 1
    • Remove the fan and heatsink from the laptop.
    • Make sure to wipe off the existing thermal paste from the CPU and heatsink with an alcohol-soaked pad and apply a new layer.
  7. Dell Latitude E7470 Motherboard Replacement, Motherboard: 手順 7、 3の画像 1 Dell Latitude E7470 Motherboard Replacement, Motherboard: 手順 7、 3の画像 2 Dell Latitude E7470 Motherboard Replacement, Motherboard: 手順 7、 3の画像 3
    • Remove all the screws using a Phillips #0 screwdriver.
    • Disconnect all of the cables from the motherboard.
  8. Dell Latitude E7470 Motherboard Replacement: 手順 8、 1の画像 1
    • Remove the motherboard from the laptop.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Bo Zeng
メンバー登録日: 10/01/19
385 ポイント
3のガイドは作成済み
コメント 1 件
Good overall, the motherboard screw picture shows too many screws. Also, might need a picture of removing the two side screws for the port cover, and that there are two screws next to the expansion port, under the port cover.
Charles Coburn - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 34
今までの合計 3,604
