はじめに
The motherboard is the central hub for communication between all of the components in a device. When one or more components are failing, the motherboard may need to be replaced. Use this guide to replace the motherboard in your laptop.
必要な工具と部品
Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
After opening the backcase of the computer, remove the screws using the Phillips #0 screwdriver.
Unplug and remove the wire from the socket.
Remove all the screws using a Phillips #0 screwdriver.
Disconnect all of the cables from the motherboard.
2 の人々がこのガイドを完成させました。
コメント 1 件
Good overall, the motherboard screw picture shows too many screws. Also, might need a picture of removing the two side screws for the port cover, and that there are two screws next to the expansion port, under the port cover.
