メインコンテンツにスキップ
Dell Latitude E7440 Hard Drive Replacement
必要な工具と部品
  1. Dell Latitude E7440 Hard Drive Replacement, Prepare the laptop: 手順 1、 1の画像 1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 Hard Drive Replacement, Release the battery: 手順 2、 3の画像 1 Dell Latitude E7440 Hard Drive Replacement, Release the battery: 手順 2、 3の画像 2 Dell Latitude E7440 Hard Drive Replacement, Release the battery: 手順 2、 3の画像 3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 Hard Drive Replacement, Remove the battery: 手順 3、 1の画像 1
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 Hard Drive Replacement, Hard Drive: 手順 4、 3の画像 1 Dell Latitude E7440 Hard Drive Replacement, Hard Drive: 手順 4、 3の画像 2 Dell Latitude E7440 Hard Drive Replacement, Hard Drive: 手順 4、 3の画像 3
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
    • Slide the service tray using the middle stand offs to then be able to lift the tray off.
  5. Dell Latitude E7440 Hard Drive Replacement: 手順 5、 2の画像 1 Dell Latitude E7440 Hard Drive Replacement: 手順 5、 2の画像 2
    • Remove four M2 x 3mm Phillips #0 screws from the hard drive cage.
    • Remove the hard drive cage by lifting it off the laptop.
    • The hard drive cage is not pictured here, but the screws will be in these locations.
  6. Dell Latitude E7440 Hard Drive Replacement: 手順 6、 2の画像 1 Dell Latitude E7440 Hard Drive Replacement: 手順 6、 2の画像 2
    • Disconnect the hard drive connector from the top of the drive.
    • iFixit's device came without a hard drive to picture. Your device will have a component connected to the thin, black connector.
    • The hard drive connector can be removed from the laptop body to make replacement easier.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Akash Kedia
メンバー登録日: 01/24/19
1,445 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S2-G5, White Winter 2019 Cal Poly, Team S2-G5, White Winter 2019人のメンバー
CPSU-WHITE-W19S2G5
4 メンバー
5のガイドは作成済み
3 件のコメント
Hi, my problem is the opposite, I have an hard drive but seems like my HDD connector doesn't plug in the small port. I can send you a pic, I need help
†Winterfall† - 返信
I want to use a Seagate hard disk, but when I start it, it demands me a password. Can you help me in this case please?
Aldoni JB - 返信
It sounds like your BIOS is locked to only work with that hard drive
Magnus Vacuum -
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 28
過去 30 日: 84
今までの合計 12,161
