メインコンテンツにスキップ
Dell Latitude E7440 Hard Drive Cable Replacement
必要な工具と部品
  1. Dell Latitude E7440 Hard Drive Cable Replacement, Prepare the laptop: 手順 1、 1の画像 1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 Hard Drive Cable Replacement, Release the battery: 手順 2、 3の画像 1 Dell Latitude E7440 Hard Drive Cable Replacement, Release the battery: 手順 2、 3の画像 2 Dell Latitude E7440 Hard Drive Cable Replacement, Release the battery: 手順 2、 3の画像 3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 Hard Drive Cable Replacement, Remove the battery: 手順 3、 1の画像 1
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 Hard Drive Cable Replacement, Remove the bottom screws: 手順 4、 2の画像 1 Dell Latitude E7440 Hard Drive Cable Replacement, Remove the bottom screws: 手順 4、 2の画像 2
    • EET owners: Your kit has this bit. No purchase needed.
    • After removing the battery, remove the 2 Phillips #0 screws securing the service panel.
    • Slide the panel off after removing the screws.
  5. Dell Latitude E7440 Hard Drive Cable Replacement, Remove the original HD cable: 手順 5、 3の画像 1 Dell Latitude E7440 Hard Drive Cable Replacement, Remove the original HD cable: 手順 5、 3の画像 2 Dell Latitude E7440 Hard Drive Cable Replacement, Remove the original HD cable: 手順 5、 3の画像 3
    • If your E7440 is missing the caddy or bumpers, these parts can be safely omitted if an SSD is installed. If your unit is complete, remove the 4 screws marked in red. These screws are Phillips #0 if your laptop has them.
    • Pull the tab on the drive cable up to disconnect it from the motherboard.
    • Deroute the hard drive cable from the system.
  6. Dell Latitude E7440 Hard Drive Cable Replacement, Remove the drive and cable: 手順 6、 2の画像 1 Dell Latitude E7440 Hard Drive Cable Replacement, Remove the drive and cable: 手順 6、 2の画像 2
    • If you are removing the cable to complete a different repair, do not use force.
    • Remove the drive from the machine, and disconnect the cable.
  7. Dell Latitude E7440 Hard Drive Cable Replacement, Install the new HD cable: 手順 7、 2の画像 1 Dell Latitude E7440 Hard Drive Cable Replacement, Install the new HD cable: 手順 7、 2の画像 2
    • Once the old cable is removed, partially install the replacement cable. Final placement is done with the drive installed.
    • Reinstall the drive into the laptop, and setup the final cable placement.
終わりに
作成者
2人の作成者と共同で作成されました。
Nick
メンバー登録日: 11/10/09
93,444 ポイント
59のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
327 メンバー
1,698のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 23
過去 30 日: 42
今までの合計 1,108
