メインコンテンツにスキップ
Dell Latitude E7270 Motherboard Removal
必要な工具と部品
  1. Dell Latitude E7270 Motherboard Removal, Back Panel: 手順 1、 1の画像 1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Motherboard Removal: 手順 2、 1の画像 1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Motherboard Removal: 手順 3、 1の画像 1
    • Lift and remove the panel.
  4. Dell Latitude E7270 Motherboard Removal, Battery: 手順 4、 1の画像 1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Motherboard Removal: 手順 5、 2の画像 1 Dell Latitude E7270 Motherboard Removal: 手順 5、 2の画像 2
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Motherboard Removal: 手順 6、 1の画像 1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 Motherboard Removal, Cooling Fan: 手順 7、 3の画像 1 Dell Latitude E7270 Motherboard Removal, Cooling Fan: 手順 7、 3の画像 2 Dell Latitude E7270 Motherboard Removal, Cooling Fan: 手順 7、 3の画像 3
    • Remove the 4 pin fan power connector from the motherboard by using your finger and pulling up.
    • Remove the four M2.5 X 5MM screws that hold on the rectangular bracket located towards the center of the motherboard using a Phillips #00 screwdriver.
    • Remove the three M2.5 X 5MM screws that hold down the circular fan bracket using a Phillips #00 screwdriver.
  8. Dell Latitude E7270 Motherboard Removal: 手順 8、 1の画像 1
    • Lift and remove fan by pulling gently straight up using your fingers
  9. Dell Latitude E7270 Motherboard Removal: 手順 9、 1の画像 1
    • Before replacing fan, make sure to place a small amount of thermal paste to ensure proper heat dissipation and long term life.
  10. Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: 手順 10、 3の画像 1 Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: 手順 10、 3の画像 2 Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: 手順 10、 3の画像 3
    • Remove the 10 wire connections by using your fingers to separate the connections.
    • Remove the thirteen M2.5 X 5MM screws that fasten the motherboard using a Phillips #00 screwdriver.
    • Remove the two M2.5 X 8MM external screws that fasten the motherboard from outside using a Phillips #00 screwdriver.
  11. Dell Latitude E7270 Motherboard Removal: 手順 11、 1の画像 1
    • Lift and remove the motherboard by grabbing the outside edges and pulling straight up.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jacob Clement
メンバー登録日: 01/14/20
876 ポイント
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 49
今までの合計 3,103
