メインコンテンツにスキップ
はじめに
The LCD (liquid crystal display) screen may need to be replaced if it is cracked or to improve resolution.
パーツ
パーツは指定されていません。
  1. With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop. When the latches are unlocked, a small logo resembling an open padlock will become visible.
    • With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
    • When the latches are unlocked, a small logo resembling an open padlock will become visible.
  2. Grasp the battery from the top and pull upward. Grasp the battery from the top and pull upward.
    • Grasp the battery from the top and pull upward.
  3. Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    SKIPANDSAVE10
    Save Now
  4. Gently pry the protective LCD cover from around the screen. You shouldn't have a problem just using your fingers.
    • Gently pry the protective LCD cover from around the screen. You shouldn't have a problem just using your fingers.
  5. Remove the six 5.75 mm JIS #0 screws that hold the LCD screen to the cover. Remove the six 5.75 mm JIS #0 screws that hold the LCD screen to the cover.
    • Remove the six 5.75 mm JIS #0 screws that hold the LCD screen to the cover.
  6. Once all the screws have been removed, lay the screen down on the keyboard and disconnect the LCD cable. Once all the screws have been removed, lay the screen down on the keyboard and disconnect the LCD cable.
    • Once all the screws have been removed, lay the screen down on the keyboard and disconnect the LCD cable.
まとめ
ある他の人がこのガイドを完成しました。
Alec Weiss
メンバー登録日: 2018年11月05日
752 ポイント
8のガイドは作成済み
チーム
IUPUI, Team S2-G2, Baechle Fall 2018 IUPUI, Team S2-G2, Baechle Fall 2018人のメンバー
IUPUI-BAECHLE-F18S2G2
3 メンバー
8のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 31
今までの合計 236
