メインコンテンツにスキップ
Dell Latitude E6430 thermal paste Replacement
必要な工具と部品
  1. Dell Latitude E6430 thermal paste Replacement, Opening up: 手順 1、 3の画像 1 Dell Latitude E6430 thermal paste Replacement, Opening up: 手順 1、 3の画像 2 Dell Latitude E6430 thermal paste Replacement, Opening up: 手順 1、 3の画像 3
    • Start by removing the battery using the 2 latches (red rectangles)
    • All screws to be removed are marked with a D (green circles)
    • The hard disk or ssd has a shared screw with the d-cover (backcover). Also remove the screw below. (blue circle)
  2. Dell Latitude E6430 thermal paste Replacement, DVD drive: 手順 2、 2の画像 1 Dell Latitude E6430 thermal paste Replacement, DVD drive: 手順 2、 2の画像 2
    • To remove the dvd drive just press on the button marked with a red rectangle.
    • It will then pop out and may be used to just pull out the drive. Easy as cake.
  3. Dell Latitude E6430 thermal paste Replacement, Lift the lid: 手順 3、 3の画像 1 Dell Latitude E6430 thermal paste Replacement, Lift the lid: 手順 3、 3の画像 2 Dell Latitude E6430 thermal paste Replacement, Lift the lid: 手順 3、 3の画像 3
    • To finally open the device turn it by 180 degrees and pry open from the backside with a spudger.
    • You will see that the d-cover is mounted to the other side.
    • Remove the cover and turn the device back like seen in image no 3.
  4. Dell Latitude E6430 thermal paste Replacement, Removing the heatsink: 手順 4、 3の画像 1 Dell Latitude E6430 thermal paste Replacement, Removing the heatsink: 手順 4、 3の画像 2 Dell Latitude E6430 thermal paste Replacement, Removing the heatsink: 手順 4、 3の画像 3
    • There are four screws with springs on them which have to be removed in the order embossed on the heatsink. (red circles)
    • Also make sure to unplug the fan very carefully. (pink rectangle)
    • Remove the heatsink by lifting it out to the left side as it is fixed on the right side.
    • The cpu DIE lies bare in front of you - this is a very sensitive part. This is why the heatsink is screwed on in a particular order.
  5. Dell Latitude E6430 thermal paste Replacement, Cleaning: 手順 5、 3の画像 1 Dell Latitude E6430 thermal paste Replacement, Cleaning: 手順 5、 3の画像 2 Dell Latitude E6430 thermal paste Replacement, Cleaning: 手順 5、 3の画像 3
    • Both the cpu DIE and the copper part of the heatsink should be cleaned as the thermal paste tends to dry out over time.
    • Use a cotton swab with some rubbing alcohol.
    • Never use a screwdriver or anything hard that might damage or scratch the surface.
  6. Dell Latitude E6430 thermal paste Replacement, Reapply thermal paste: 手順 6、 1の画像 1
    • Use thermal paste of your liking and apply a thin layer (I almost used too much).
    • The thermal pad (red circle) should not be replaced with thermal paste. If it seems dried out you have to use one of the same size.
    • Reattach the heatsink very carefully and tighten the screws in the given order. Also don't forget to connect the fan.
    • If your fan seems to be clogged with dust you should clean it while it's removed.
終わりに
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Fred
3,522 ポイント
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 40
今までの合計 1,562
