メインコンテンツにスキップ
Dell Latitude E6430 Keyboard Replacement
必要な工具と部品
  1. Dell Latitude E6430 Keyboard Replacement, Removing the battery: 手順 1、 3の画像 1 Dell Latitude E6430 Keyboard Replacement, Removing the battery: 手順 1、 3の画像 2 Dell Latitude E6430 Keyboard Replacement, Removing the battery: 手順 1、 3の画像 3
    • As always before laying hand on any electronic device we have to remove the battery. Also make sure you haven't connected the power supply.
    • To remove the battery turn the device around and look for the two latches on the left and right side (red rectangles).
    • With the battery removed you may now remove the two screws next to the docking station connector (green circles)
  2. Dell Latitude E6430 Keyboard Replacement, Keyboard frame: 手順 2、 3の画像 1 Dell Latitude E6430 Keyboard Replacement, Keyboard frame: 手順 2、 3の画像 2 Dell Latitude E6430 Keyboard Replacement, Keyboard frame: 手順 2、 3の画像 3
    • Turn around the device and open the screen. Before the keyboard may be removed you have to remove the frame around it.
    • Use a spudger between the c-cover and the frame. Begin at the top and don't be shy as the frame is quite sturdy and flexible.
    • With the frame removed it should look like in the last photo.
  3. Dell Latitude E6430 Keyboard Replacement, Keyboard removal: 手順 3、 3の画像 1 Dell Latitude E6430 Keyboard Replacement, Keyboard removal: 手順 3、 3の画像 2 Dell Latitude E6430 Keyboard Replacement, Keyboard removal: 手順 3、 3の画像 3
    • There are four screws which have to be unscrewed to proceed.
    • Lift up the keyboard carefully as it is still connected by a ribbon cable. (green rectangle)
    • To be able to pull out the ribbon cable you have to lift the plastic lever on top in the direction of the orange arrow.
  4. Dell Latitude E6430 Keyboard Replacement, Finished!: 手順 4、 1の画像 1
    • Congratulations. You have successfully removed the keyboard.
    • You may now replace it with a spare.
    • With the keyboard removed you could remove dust and crumbs accumulated in your notebook.
終わりに
作成者
1人の作成者と共同作成されました。
Fred
3,522 ポイント
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 24
今までの合計 1,379
