メインコンテンツにスキップ
Dell Latitude E6420 Wireless Card Replacement
必要な工具と部品
  1. Dell Latitude E6420 Wireless Card Replacement, Battery: 手順 1、 2の画像 1 Dell Latitude E6420 Wireless Card Replacement, Battery: 手順 1、 2の画像 2
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Wireless Card Replacement: 手順 2、 1の画像 1
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Wireless Card Replacement, CD/DVD Drive: 手順 3、 2の画像 1 Dell Latitude E6420 Wireless Card Replacement, CD/DVD Drive: 手順 3、 2の画像 2
    • Push the button in on the CD/DVD drive to eject the drive.
  4. Dell Latitude E6420 Wireless Card Replacement: 手順 4、 2の画像 1 Dell Latitude E6420 Wireless Card Replacement: 手順 4、 2の画像 2
    • Slide the drive out of the laptop.
    • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  5. Dell Latitude E6420 Wireless Card Replacement, Backplate: 手順 5、 2の画像 1 Dell Latitude E6420 Wireless Card Replacement, Backplate: 手順 5、 2の画像 2
    • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
    • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  6. Dell Latitude E6420 Wireless Card Replacement: 手順 6、 2の画像 1 Dell Latitude E6420 Wireless Card Replacement: 手順 6、 2の画像 2
    • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
    • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
  7. Dell Latitude E6420 Wireless Card Replacement, Wireless Card: 手順 7、 2の画像 1 Dell Latitude E6420 Wireless Card Replacement, Wireless Card: 手順 7、 2の画像 2
    • Using the screwdriver, remove two 4mm JIS #0 screws.
  8. Dell Latitude E6420 Wireless Card Replacement: 手順 8、 3の画像 1 Dell Latitude E6420 Wireless Card Replacement: 手順 8、 3の画像 2 Dell Latitude E6420 Wireless Card Replacement: 手順 8、 3の画像 3
    • Disconnect 4 wires by pulling upward.
    • Gently remove the wires to prevent damaging them.
  9. Dell Latitude E6420 Wireless Card Replacement: 手順 9、 1の画像 1
    • Lift the wiring harness out of the way.
  10. Dell Latitude E6420 Wireless Card Replacement: 手順 10、 3の画像 1 Dell Latitude E6420 Wireless Card Replacement: 手順 10、 3の画像 2 Dell Latitude E6420 Wireless Card Replacement: 手順 10、 3の画像 3
    • The card will lift up, remove the card by pulling the lifted edge away from you.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Madysen Eames
メンバー登録日: 02/27/18
1,555 ポイント
7のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G3, Simcock Spring 2018 UMass Dartmouth, Team S2-G3, Simcock Spring 2018人のメンバー
UMASSD-SIMCOCK-S18S2G3
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 39
過去 30 日: 53
今までの合計 2,261
