メインコンテンツにスキップ
Dell Latitude E6400 Screen Replacement
必要な工具と部品
  1. Dell Latitude E6400 Screen Replacement, Battery Removal: 手順 1、 3の画像 1 Dell Latitude E6400 Screen Replacement, Battery Removal: 手順 1、 3の画像 2 Dell Latitude E6400 Screen Replacement, Battery Removal: 手順 1、 3の画像 3
    • Disconnect AC power adaptor
    • Push battery release tabs inwards.
    • Slide the battery out of the computer.
  2. Dell Latitude E6400 Screen Replacement, Display Plastic Lids: 手順 2、 3の画像 1 Dell Latitude E6400 Screen Replacement, Display Plastic Lids: 手順 2、 3の画像 2 Dell Latitude E6400 Screen Replacement, Display Plastic Lids: 手順 2、 3の画像 3
    • Remove the two 4.8mm Phillips screws securing the plastic lids.
    • Slide the plastic lids of the case
  3. Dell Latitude E6400 Screen Replacement, Display Data Cable: 手順 3、 2の画像 1 Dell Latitude E6400 Screen Replacement, Display Data Cable: 手順 3、 2の画像 2
    • Grab the plastic pull tab secured to the display data cable lock and pull the display data cable connector straight up from its socket.
    • De-route the display data cable from the channel.
  4. Dell Latitude E6400 Screen Replacement, Wi-Fi Antenna Cable: 手順 4、 2の画像 1 Dell Latitude E6400 Screen Replacement, Wi-Fi Antenna Cable: 手順 4、 2の画像 2
    • Using spudger lift and disconnect Wi-Fi antenna cable.
    • De-route the Wi-Fi antenna cable from it's channel.
  5. Dell Latitude E6400 Screen Replacement, Display Assembly: 手順 5、 3の画像 1 Dell Latitude E6400 Screen Replacement, Display Assembly: 手順 5、 3の画像 2 Dell Latitude E6400 Screen Replacement, Display Assembly: 手順 5、 3の画像 3
    • Open your laptop so the display is perpendicular to the upper case.
    • Place your opened MacBook on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the two 4.8 mm Phillips screws from the display brackets.
    • Grab the upper case with your right hand and rotate the display slightly away from the upper case. Lift the display away from the upper case, minding any brackets or cables that may get caught.
終わりに
作成者
1人の作成者と共同作成されました。
D. K. Labudek
メンバー登録日: 03/09/18
685 ポイント
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 23
今までの合計 183
