メインコンテンツにスキップ
Dell Latitude E6400 CMOS/Coin Cell Battery Replacement
必要な工具と部品
    • First, turn off your laptop and disconnect any external adapter.
  1. Dell Latitude E6400 CMOS/Coin Cell Battery Replacement: 手順 2、 1の画像 1
    • Release the latch or latches connected to the battery that hold it in place.
  2. Dell Latitude E6400 CMOS/Coin Cell Battery Replacement: 手順 3、 1の画像 1
    • Remove the old battery from its storage bay.
    • Plug in the external AC adapter to fully charge the new battery.
  3. Dell Latitude E6400 CMOS/Coin Cell Battery Replacement, Remove the access panel: 手順 5、 1の画像 1
    • After removing the battery, loosen the screw holding the access panel in place. Then, slide the access panel away from the hinge covers, and lift to remove the access panel..
  4. Dell Latitude E6400 CMOS/Coin Cell Battery Replacement, Remove the coin-cell battery: 手順 6、 1の画像 1
    • Pry up the coin-cell battery to release the double-stick adhesive tape on the bottom of the coin-cell battery, then lift it out of the computer. Then, disconnect the coin-cell battery cable from the system board.
  5. Dell Latitude E6400 CMOS/Coin Cell Battery Replacement, Install new coin-cell battery: 手順 7、 1の画像 1
    • With your replacement battery, coin-cell battery cable to the system board. Then, remove the adhesive backing paper from the coin-cell battery. Slide the battery under the tab, then press down to seal the tape on bottom.
終わりに
Reassemble your device by performing the instructions above in reverse order.
作成者
1人の作成者と共同作成されました。
Aaron Thomas
メンバー登録日: 02/16/21
1,194 ポイント
10のガイドは作成済み
チーム
Informative Technologies Inc. Informative Technologies Inc.人のメンバー
Community
38 メンバー
1,983のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 71
今までの合計 1,330
