必要な工具と部品
Using your fingers or a pry tool, gently lift the cover from the device. If the device has been opened before, it should open easily from the top corner using your finger.
If it is a tight fit, a spudger can be used to gently pry open the cover. Place the spudger at the top corner to pry open.
もう少しです!
終わりに
