メインコンテンツにスキップ
Dell Latitude E5450-5450 LCD Screen Replacement
必要な工具と部品
  1. Dell Latitude E5450-5450 LCD Screen Replacement, Unscrew the Lower Case: 手順 1、 1の画像 1
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    購入する
    • Remove the six Philips #0 screws from the lower case.
    • These screws are all 5.6 mm long, but it's still a good idea to keep track of them and make sure they go back in their proper holes!
  2. Dell Latitude E5450-5450 LCD Screen Replacement: 手順 2、 1の画像 1
    • This photo shows the location of the ten clips that hold the lower case in place. Take note of the location of the clips, and refer back to this step if your lower case gets stuck during removal.
    • Four clips hold the upper half of the case in place and can be released by prying around them with a spudger.
    • The other six clips along the bottom edge can not be released by prying at them. Instead, they come free by sliding the whole case upward, as shown in step 5 below.
  3. Dell Latitude E5450-5450 LCD Screen Replacement: 手順 3、 2の画像 1 Dell Latitude E5450-5450 LCD Screen Replacement: 手順 3、 2の画像 2
    • Insert the flat edge of a spudger into the small divot along the top edge of the case, just below the docking station port.
    • Pry up to release the two central clips along the upper edge of the case.
  4. Dell Latitude E5450-5450 LCD Screen Replacement: 手順 4、 3の画像 1 Dell Latitude E5450-5450 LCD Screen Replacement: 手順 4、 3の画像 2 Dell Latitude E5450-5450 LCD Screen Replacement: 手順 4、 3の画像 3
    • Use your spudger to pry up the remaining clips along the top edge.
  5. Dell Latitude E5450-5450 LCD Screen Replacement, Remove the Lower Case: 手順 5、 3の画像 1 Dell Latitude E5450-5450 LCD Screen Replacement, Remove the Lower Case: 手順 5、 3の画像 2 Dell Latitude E5450-5450 LCD Screen Replacement, Remove the Lower Case: 手順 5、 3の画像 3
    • Slide the lower case upward and remove it.
  6. Dell Latitude E5450-5450 LCD Screen Replacement: 手順 6、 2の画像 1 Dell Latitude E5450-5450 LCD Screen Replacement: 手順 6、 2の画像 2
    • When reinstalling the lower case, make sure you slide the bottom edge (the edge without the cutout) into place first before snapping the rest of the clips shut.
  7. Dell Latitude E5450-5450 LCD Screen Replacement, Disconnect the Battery: 手順 7、 2の画像 1 Dell Latitude E5450-5450 LCD Screen Replacement, Disconnect the Battery: 手順 7、 2の画像 2
    • Pull up on the battery connector's pull tab to disconnect the battery.
  8. Dell Latitude E5450-5450 LCD Screen Replacement, Unscrew the Battery: 手順 8、 1の画像 1
    • Remove the three 5.6 mm Philips #0 screws from the top edge of the battery.
  9. Dell Latitude E5450-5450 LCD Screen Replacement, Remove the Battery: 手順 9、 3の画像 1 Dell Latitude E5450-5450 LCD Screen Replacement, Remove the Battery: 手順 9、 3の画像 2 Dell Latitude E5450-5450 LCD Screen Replacement, Remove the Battery: 手順 9、 3の画像 3
    • Remove the battery from the laptop.
    • The battery cell extends below the bottom lip of the enclosure. Make sure you lift the battery away from the bottom edge of the laptop at an angle, as shown in the photos.
  10. Dell Latitude E5450-5450 LCD Screen Replacement: 手順 10、 2の画像 1 Dell Latitude E5450-5450 LCD Screen Replacement: 手順 10、 2の画像 2
    • When installing your new battery, slide the bottom edge in first, and make sure it lays flat before you proceed to reinsert the screws or reconnect it.
  11. Dell Latitude E5450-5450 LCD Screen Replacement, LCD Screen: 手順 11、 1の画像 1
    • Flip the laptop so the front panel is facing you.
    • Open the laptop.
  12. Dell Latitude E5450-5450 LCD Screen Replacement: 手順 12、 2の画像 1 Dell Latitude E5450-5450 LCD Screen Replacement: 手順 12、 2の画像 2
    • Remove the plastic cover surrounding the screen.
    • Remove the four Phillips #0 screws from each corner of the laptop.
  13. Dell Latitude E5450-5450 LCD Screen Replacement: 手順 13、 2の画像 1 Dell Latitude E5450-5450 LCD Screen Replacement: 手順 13、 2の画像 2
    • Carefully put the screen upside down on the keyboard.
    • Disconnect the cable with the QR code on the opposite side of the screen.
  14. Dell Latitude E5450-5450 LCD Screen Replacement: 手順 14、 1の画像 1
    • Remove the screen from the laptop.
終わりに
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, then please reapply it and let it dry before you start using the laptop.
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Tulsi Panchal
メンバー登録日: 09/17/20
157 ポイント
1ガイドが承認済み
チーム
York University, Team S2-G19, Melo-Thaiss Fall 2020 York University, Team S2-G19, Melo-Thaiss Fall 2020人のメンバー
YORK-MELO-THAISS-F20S2G19
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 39
今までの合計 2,556
