必要な工具と部品
After removing the battery, loosen the screw that secures the access panel to the computer. Then, lift up the access panel at an angle and remove it from the computer.
Disconnect the coin-cell battery cable from the system board.
Slide the coin-cell battery from its socket.
もう少しです!
With you new battery, reassemble your device by performing the instructions above in reverse order.
終わりに
