メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
Is your laptop out of storage or not reading files correctly? Consider using this guide to replace the hard drive of your laptop.
パーツ
パーツは指定されていません。
  1. Open the laptop and remove the small panel located above the keyboard.
    • Open the laptop and remove the small panel located above the keyboard.
  2. Using a Phillips 1 Screwdriver, unscrew the three M2x3-mm screws located above the keyboard where the small panel was originally.
    • Using a Phillips 1 Screwdriver, unscrew the three M2x3-mm screws located above the keyboard where the small panel was originally.
  3. Pull off keyboard forward and then outwards.
    • Pull off keyboard forward and then outwards.
    • The keyboard is fragile, so make sure you pull the keyboard off carefully.
  4. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  5. With your Phillips 1 screwdriver, unscrew the five M2.5x5-mm screws and the five M2.5x8-mm screws that lie underneath the keyboard panel.
    • With your Phillips 1 screwdriver, unscrew the five M2.5x5-mm screws and the five M2.5x8-mm screws that lie underneath the keyboard panel.
    • Be aware there are two deeply recessed screws on both sides to the rear of this panel. There are also two screws externally on the rear face either side of the battery that hold the monitor on and pass through this panel, support the screen when you remove these. There are also two screws above the hard drive bay that need to be removed.
  6. Remove additional wires located within the panel. For the smaller wires, try using a spudger for easier access.
    • Remove additional wires located within the panel.
    • For the smaller wires, try using a spudger for easier access.
  7. Lift the keyboard panel to separate the component from the rest of the device.
    • Lift the keyboard panel to separate the component from the rest of the device.
  8. Unscrew the three screws located on the top of the component. Lift the hard drive out of its holding in an outward motion and remove it from the device.
    • Unscrew the three screws located on the top of the component.
    • Lift the hard drive out of its holding in an outward motion and remove it from the device.
終わりに
Ryan Blakey
メンバー登録日: 2018年09月24日
172 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S6-G5, Thompson Fall 2018 University of North Texas, Team S6-G5, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S6G5
4 メンバー
5のガイドは作成済み
2 件のコメント
What!?! You can simple remove the hard drive by undoing two screws on the bottom of the laptop. Then you can remove the bezel from the laptop by undoing one more screw. It’s detailed in the service manual on the Dell website.
Rob Walter - 返信
I agree with Rob. It’s been made very easy. Pretty much the same as model E4310 here Dell Latitude E4310 Hard Drive Replacement.
Gwenole Capp - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 24
今までの合計 412
