メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Dell Latitude E4300 CPU Cooling Fan Replacement
必要な工具と部品
  1. Dell Latitude E4300 CPU Cooling Fan Replacement, Keyboard: 手順 1、 1の画像 1
    • Open the laptop and remove the small panel located above the keyboard.
  2. Dell Latitude E4300 CPU Cooling Fan Replacement: 手順 2、 1の画像 1
    • Using a Phillips 1 Screwdriver, unscrew the three M2x3-mm screws located above the keyboard where the small panel was originally.
  3. Dell Latitude E4300 CPU Cooling Fan Replacement: 手順 3、 1の画像 1
    • Pull off keyboard forward and then outwards.
    • The keyboard is fragile, so make sure you pull the keyboard off carefully.
  4. Dell Latitude E4300 CPU Cooling Fan Replacement, Keyboard Docking Component: 手順 4、 1の画像 1
    • With your Phillips 1 screwdriver, unscrew the five M2.5x5-mm screws and the five M2.5x8-mm screws that lie underneath the keyboard panel.
    • Be aware there are two deeply recessed screws on both sides to the rear of this panel. There are also two screws externally on the rear face either side of the battery that hold the monitor on and pass through this panel, support the screen when you remove these. There are also two screws above the hard drive bay that need to be removed.
  5. Dell Latitude E4300 CPU Cooling Fan Replacement: 手順 5、 2の画像 1 Dell Latitude E4300 CPU Cooling Fan Replacement: 手順 5、 2の画像 2
    • Remove additional wires located within the panel.
    • For the smaller wires, try using a spudger for easier access.
  6. Dell Latitude E4300 CPU Cooling Fan Replacement: 手順 6、 1の画像 1
    • Lift the keyboard panel to separate the component from the rest of the device.
  7. Dell Latitude E4300 CPU Cooling Fan Replacement, CPU Cooling Fan: 手順 7、 1の画像 1
    • Using a Phillips 1 Screwdriver, remove the two M2.5x5-mm screws located on opposite sides of the fan.
  8. Dell Latitude E4300 CPU Cooling Fan Replacement: 手順 8、 1の画像 1
    • Disconnect the wires that connect the fan to the rest of the computer.
  9. Dell Latitude E4300 CPU Cooling Fan Replacement: 手順 9、 1の画像 1
    • Lift the fan upwards and remove it from the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Maritza Martinez
メンバー登録日: 09/21/18
324 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S6-G5, Thompson Fall 2018 University of North Texas, Team S6-G5, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S6G5
4 メンバー
5のガイドは作成済み
コメント 1 件
I would rate this more moderate than easy.
Bob Green - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 2,323
