メインコンテンツにスキップ
Dell Latitude E4200 LED Cover Replacement
必要な工具と部品
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • Remove the battery from the computer.
  1. Dell Latitude E4200 LED Cover Replacement, Open the display all the way.: 手順 2、 1の画像 1
    • Open the display all the way (160 degrees).
    • To avoid damaging the LED cover, do not lift the cover on both sides simultaneously. Removing the LED cover in a different way than described may cause the plastic to break.
    • Starting on the right side of the computer, use a plastic scribe (inserted into the indent) to pry up the hinge cover. Lift the bottom edge of the cover away from the keyboard going from the right to the left, and then pull the cover up and away from the display to remove it.
    • Before installing the LED cover, ensure that all cables are routed correctly. Improper routing of the cables can cause damage to the cables.
    • Insert the tabs on the top edge of the cover into the slots under the bottom edge of the display.
    • Press from left to right until the cover snaps into place, ensuring that the edges of the cover line up with those on the palm rest.
終わりに
作成者
1人の作成者と共同作成されました。
Hezekiah Brown
メンバー登録日: 02/11/21
6,169 ポイント
49のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 132
