メインコンテンツにスキップ
Dell Latitude D820 Keyboard Replacement
必要な工具と部品
  1. Dell Latitude D820 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Remove the charger from the laptop.
    • Turn the laptop over and locate the battery slide lock. Slide the switch and gently lift up the battery.
    • If you are replacing other components, leave the battery out.
    • If you are only replacing the battery, reverse the steps to install a new battery.
  2. Dell Latitude D820 Keyboard Replacement, Keyboard: 手順 2、 3の画像 1 Dell Latitude D820 Keyboard Replacement, Keyboard: 手順 2、 3の画像 2 Dell Latitude D820 Keyboard Replacement, Keyboard: 手順 2、 3の画像 3
    • Open laptop lid and extend screen until it is parallel with the keyboard.
    • Locate the notch in the upper right corner of the keyboard (just above the 'page up' button).
    • Insert the plastic spudger and very gently lift the faceplate. It will make a soft snapping sound.
    • Set aside.
  3. Dell Latitude D820 Keyboard Replacement: 手順 3、 1の画像 1
    • Locate the three philips head screws above the keyboard. One is above the 'Pause/Break' key; one above the F7 key and one above the 'Esc' key. Remove all three.
  4. Dell Latitude D820 Keyboard Replacement: 手順 4、 1の画像 1
    • Gently lift top of keyboard and lay forward on palm rest.
    • Locate blue pull tab and gently disconnect ribbon cable from motherboard.
終わりに
5 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Michael Coleman
メンバー登録日: 09/09/14
162 ポイント
1ガイドが承認済み
チーム
Pasco Hernando, Team 1-2, Prince Fall 2014 Pasco Hernando, Team 1-2, Prince Fall 2014人のメンバー
PHSC-PRINCE-F14S1G2
10 メンバー
7のガイドは作成済み
4 件のコメント
I am the author of a high-altitude cookbook. I self-publish. My "A" key decided to stop working on my dell XP, and then the internet would not connect. When I finally purchased a new computer Windows 8, I discovered I could not format it for my hp business injet 2300. This printer is a duplexer, and key to my cookbook business. The other problem was Quark Express 6.1 would not work on it. Two thousand plus seemed a little high for a new Quark. After fiddling around with the internal keyboard and using the "copy and replace function" I decided on a new keyboard. Found a new one on ebay cheap. The instructions here were a blessing. Thank you, thank you, thank you! I now have my XP back working like new. The Windows 8 can be for the internet,
DAWN KLEIN - 返信
Thank you very much. I am glad it helped and your back up and running. Just a side note: Be careful using Windows XP on the Internet these days, since it no longer receives security updates from Microsoft. Thanks again!
Henry -
You gave great directions. I never reassembled something I took apart. Worked like a charm Thanks so much!!!
Cheryl Baynard - 返信
Beautifully clear - perfect! Thank you.
David Harmsworth - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 2,033
