メインコンテンツにスキップ
Dell Latitude D630 Hard Drive Replacement
必要な工具と部品
  1. Dell Latitude D630 Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Hard Drive Replacement: 手順 2、 1の画像 1
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 Hard Drive Replacement, Hard Drive: 手順 3、 3の画像 1 Dell Latitude D630 Hard Drive Replacement, Hard Drive: 手順 3、 3の画像 2 Dell Latitude D630 Hard Drive Replacement, Hard Drive: 手順 3、 3の画像 3
    • Position the closed laptop upside down.
    • Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive.
    • Do not unscrew this screw!
  4. Dell Latitude D630 Hard Drive Replacement: 手順 4、 1の画像 1
    • Place thumb on the hard drive cover and get a firm grip.
    • Pull the hard drive out slowly to avoid any further damage to the laptop.
  5. Dell Latitude D630 Hard Drive Replacement: 手順 5、 2の画像 1 Dell Latitude D630 Hard Drive Replacement: 手順 5、 2の画像 2
    • Unscrew the screw on the right side to remove cover.
    • Slide cover off.
終わりに
17 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Savi Chavan
メンバー登録日: 03/12/14
979 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 1-4, Cichon Spring 2014 UMass Dartmouth, Team 1-4, Cichon Spring 2014人のメンバー
UMASSD-CICHON-S14S1G4
3 メンバー
1のガイドは作成済み
4 件のコメント
Dell latitude 2RHczd1
C Chandler - 返信
I appreciate the guide my good sir. Very helpful.
Matt Erti - 返信
Is the hard drive replaceable to 2.5-inch SSD? for example Kingston a400.
Aduh - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 24
今までの合計 15,438
