メインコンテンツにスキップ
Dell Latitude D620 Display Replacement
必要な工具と部品
  1. Dell Latitude D620 Display Replacement, Keyboard: 手順 1、 1の画像 1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
    Mera display ka masla hai
    manaqib arif - 返信
  2. Dell Latitude D620 Display Replacement: 手順 2、 3の画像 1 Dell Latitude D620 Display Replacement: 手順 2、 3の画像 2 Dell Latitude D620 Display Replacement: 手順 2、 3の画像 3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 Display Replacement: 手順 3、 1の画像 1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 Display Replacement: 手順 4、 1の画像 1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 Display Replacement: 手順 5、 2の画像 1 Dell Latitude D620 Display Replacement: 手順 5、 2の画像 2
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 Display Replacement: 手順 6、 2の画像 1 Dell Latitude D620 Display Replacement: 手順 6、 2の画像 2
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 Display Replacement: 手順 7、 1の画像 1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
  8. Dell Latitude D620 Display Replacement, Display: 手順 8、 1の画像 1
    • Detach cables that connect the display to the body of the laptop
  9. Dell Latitude D620 Display Replacement: 手順 9、 1の画像 1
    • Disconnect the black cable attached to the motherboard
  10. Dell Latitude D620 Display Replacement: 手順 10、 2の画像 1 Dell Latitude D620 Display Replacement: 手順 10、 2の画像 2
    • Close the laptop lid
    • Turn the laptop over onto its backside
    • Unscrew the two screws shown in the picture using a #00 screwdriver
  11. Dell Latitude D620 Display Replacement: 手順 11、 2の画像 1 Dell Latitude D620 Display Replacement: 手順 11、 2の画像 2
    • Face the laptop's back ports towards you
    • Unscrew the two screws labeled in the picture using a #00 screwdriver
  12. Dell Latitude D620 Display Replacement: 手順 12、 1の画像 1
    • Turn the laptop over again so it's right-side up
    • Open the display, and pull the display up and out of the laptop's body
  13. Dell Latitude D620 Display Replacement: 手順 13、 1の画像 1
    • Remove the circular rubber pads as outlined in the picture using a spudger
  14. Dell Latitude D620 Display Replacement: 手順 14、 1の画像 1
    • Unscrew the screws that were under the rubber circles using the #00 screwdriver
  15. Dell Latitude D620 Display Replacement: 手順 15、 1の画像 1
    • Carefully use a spudger to work around the edge of the screen to lift off the plastic cover
    • Be very careful while doing this as the plastic snaps easily
  16. Dell Latitude D620 Display Replacement: 手順 16、 1の画像 1
    • Remove the screws outlined in the picture
  17. Dell Latitude D620 Display Replacement: 手順 17、 1の画像 1
    • Carefully lift the LCD screen out of its casing
終わりに
19 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Miguel Wong
メンバー登録日: 04/15/10
562 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 24-35, Regan Spring 2010 Cal Poly, Team 24-35, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S24G35
4 メンバー
4のガイドは作成済み
コメント 1 件
Check out this replacement screen at a great price on bcdelectrostore.com
http://www.bcdelectrostore.com/magento/l...
bob harris - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 36
今までの合計 33,014
