メインコンテンツにスキップ
はじめに
Replacing a defective modem is fairly simple and will help your computer in connecting to networks requiring a modem.
パーツ
パーツは指定されていません。
  1. Remove the 3.9 mm Phillips #1 screw from the battery compartment. Remove the 3.9 mm Phillips #1 screw from the battery compartment.
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Locate the laptop battery release button lock Push the battery release in the direction of the arrow, and pull upward. Push the battery release in the direction of the arrow, and pull upward.
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  3. Remove the battery from its compartment.
    • Remove the battery from its compartment.
  4. Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem. Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem. Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem.
    • Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem.
  5. Lift and remove the lid. Lift and remove the lid.
    • Lift and remove the lid.
  6. Remove the 3.9mm Philips #1 screw on top of the modem. Remove the 3.9mm Philips #1 screw on top of the modem.
    • Remove the 3.9mm Philips #1 screw on top of the modem.
  7. Pull on the white tab to remove the modem Remove the cable going to the modem. Remove the cable going to the modem.
    • Pull on the white tab to remove the modem
    • Remove the cable going to the modem.
まとめ
ある他の人がこのガイドを完成しました。
Jose Chavez
メンバー登録日: 2014年01月26日
113 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 6-24, Maness Winter 2014 Cal Poly, Team 6-24, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S6G24
4 メンバー
5のガイドは作成済み
コメント1件
I have manufacturing mode problem can you help me??
Mod - 返信
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,309
