メインコンテンツにスキップ
Dell Latitude D520 disassembly and power jack repair
必要な工具と部品
  1. Dell Latitude D520 disassembly and power jack repair, Dell Latitude D520 disassembly and power jack repair: 手順 1、 1の画像 1
    • 1. unplug laptop
    • 2. remove battery
    • 3. remove screw
    • Remove disk drive by pressing in the pull mechanism, causing it to extend outwards, then use the pull handle to pull out disk drive.
  2. Dell Latitude D520 disassembly and power jack repair: 手順 2、 1の画像 1
    • remove 2 retention screws
    • slide HD carriage out
  3. Dell Latitude D520 disassembly and power jack repair: 手順 3、 1の画像 1
    • open laptop
    • with a small screwdriver carefully pry plastic cover
    • it helps to open the laptop all the way
    • be careful not to break these clips
    • The clips found under here were specially tricky
  4. Dell Latitude D520 disassembly and power jack repair: 手順 4、 3の画像 1 Dell Latitude D520 disassembly and power jack repair: 手順 4、 3の画像 2 Dell Latitude D520 disassembly and power jack repair: 手順 4、 3の画像 3
    • remove screws X 2
    • carefully lift keyboard, being careful not to damage the flat cable.
    • lift up tab to release flat cable and remove keyboard
  5. Dell Latitude D520 disassembly and power jack repair: 手順 5、 3の画像 1 Dell Latitude D520 disassembly and power jack repair: 手順 5、 3の画像 2 Dell Latitude D520 disassembly and power jack repair: 手順 5、 3の画像 3
    • disconnect the three wires
    • disconnect video connector
    • remove ground screw
    • remove 3 screws
    • remove last screw, note this screw is longer then the other three
    • remove screen
  6. Dell Latitude D520 disassembly and power jack repair: 手順 6、 3の画像 1 Dell Latitude D520 disassembly and power jack repair: 手順 6、 3の画像 2 Dell Latitude D520 disassembly and power jack repair: 手順 6、 3の画像 3
    • Remove these 15 screws, they are all the same size
    • remove screw and cover
    • flip the laptop over
    • remove touchpad flat cable by gently pulling up.
    • remove 4 screws marked with the letter P
  7. Dell Latitude D520 disassembly and power jack repair: 手順 7、 1の画像 1
    • remove top cover being careful not to break any clips
  8. Dell Latitude D520 disassembly and power jack repair: 手順 8、 2の画像 1 Dell Latitude D520 disassembly and power jack repair: 手順 8、 2の画像 2
    • remove 3 screws
    • carefully remove small metal piece that was being help down by the three screws
  9. Dell Latitude D520 disassembly and power jack repair: 手順 9、 2の画像 1 Dell Latitude D520 disassembly and power jack repair: 手順 9、 2の画像 2
    • remove 4 screws
    • remove 1 screw
    • being careful not to break any clips, separate bottom plastic cover from the mother board carriage.
  10. Dell Latitude D520 disassembly and power jack repair: 手順 10、 1の画像 1
    • The middle part of my power connector had sheared away from its solder points on the motherboard.
    • I had to use a bit of flux, but I managed to re-tin all three contact point on the motherboard, as well as the pins in the connector.
    • I re-soldered the whole thing and used my trusty hot glue gun to encase the whole connector to prevent it from happening again anytime soon.
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
otrebla
メンバー登録日: 01/08/11
323 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 22
今までの合計 9,684
