メインコンテンツにスキップ
Dell Latitude 9510 USB and Headphone Jack Replacement
必要な工具と部品
  1. Dell Latitude 9510 USB and Headphone Jack Replacement, Base Panel: 手順 1、 1の画像 1
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 USB and Headphone Jack Replacement: 手順 2、 1の画像 1
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 USB and Headphone Jack Replacement, Fan: 手順 3、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the two 3 mm screws securing the fan.
  4. Dell Latitude 9510 USB and Headphone Jack Replacement: 手順 4、 1の画像 1
    • Place your fingernails behind the plastic tabs on the speaker's motherboard connector, then pull directly backwards, toward the wires, until the connector releases from its port.
    • Lift the fan up and out.
  5. Dell Latitude 9510 USB and Headphone Jack Replacement, Speakers: 手順 5、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the four 2 mm screws from the speakers.
  6. Dell Latitude 9510 USB and Headphone Jack Replacement: 手順 6、 1の画像 1
    • Use a spudger to gently lever the speaker connector out of its port.
    • Lift the speakers up and out.
  7. Dell Latitude 9510 USB and Headphone Jack Replacement, USB and Headphone Jack Replacement: 手順 7、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the four 3.5 mm screws.
  8. Dell Latitude 9510 USB and Headphone Jack Replacement: 手順 8、 1の画像 1
    • Place your fingernails behind each of the plastic tabs on the plug, and pull directly backward until the connector releases.
  9. Dell Latitude 9510 USB and Headphone Jack Replacement: 手順 9、 1の画像 1
    • Flip up the locking bars on the two ZIF connectors so they stand vertically, then gently remove the two ribbon cables connected to the IO daughterboard.
    • Lift the IO daughterboard up and out.
終わりに
作成者
6人の作成者と共同で作成されました。
Matthew D
メンバー登録日: 02/08/22
97 ポイント
1ガイドが承認済み
チーム
Western Carolina University, Team 1-5, Virtue Spring 2022 Western Carolina University, Team 1-5, Virtue Spring 2022人のメンバー
WCU-VIRTUE-S22S1G5
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 16
今までの合計 189
