メインコンテンツにスキップ
Dell Latitude 9510 Motherboard Replacement
必要な工具と部品
  1. Dell Latitude 9510 Motherboard Replacement, Base Panel: 手順 1、 1の画像 1
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 Motherboard Replacement: 手順 2、 1の画像 1
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 Motherboard Replacement, Speakers: 手順 3、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the four 2 mm screws from the speakers.
  4. Dell Latitude 9510 Motherboard Replacement: 手順 4、 1の画像 1
    • Use a spudger to gently lever the speaker connector out of its port.
    • Lift the speakers up and out.
  5. Dell Latitude 9510 Motherboard Replacement, Fan: 手順 5、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the two 3 mm screws securing the fan.
  6. Dell Latitude 9510 Motherboard Replacement: 手順 6、 1の画像 1
    • Place your fingernails behind the plastic tabs on the speaker's motherboard connector, then pull directly backwards, toward the wires, until the connector releases from its port.
    • Lift the fan up and out.
  7. Dell Latitude 9510 Motherboard Replacement, USB and Headphone Jack Replacement: 手順 7、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the four 3.5 mm screws.
  8. Dell Latitude 9510 Motherboard Replacement: 手順 8、 1の画像 1
    • Place your fingernails behind each of the plastic tabs on the plug, and pull directly backward until the connector releases.
  9. Dell Latitude 9510 Motherboard Replacement: 手順 9、 1の画像 1
    • Flip up the locking bars on the two ZIF connectors so they stand vertically, then gently remove the two ribbon cables connected to the IO daughterboard.
    • Lift the IO daughterboard up and out.
  10. Dell Latitude 9510 Motherboard Replacement, Battery: 手順 10、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the eight screws securing the battery.
  11. Dell Latitude 9510 Motherboard Replacement: 手順 11、 1の画像 1
    • Place a spudger behind a plastic tab on either side of the plug, then "walk" the connector out of its socket by gently pushing the plug toward the cables, alternating sides, until the connector releases.
    • Lift the battery up and out.
  12. Dell Latitude 9510 Motherboard Replacement, Motherboard: 手順 12、 2の画像 1 Dell Latitude 9510 Motherboard Replacement, Motherboard: 手順 12、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the four screws.
    • Use a Phillips #00 screwdriver to remove the three screws.
  13. Dell Latitude 9510 Motherboard Replacement: 手順 13、 2の画像 1 Dell Latitude 9510 Motherboard Replacement: 手順 13、 2の画像 2
    • Flip up the small metal display cable clip, until the clip is parallel to the ribbon cable, then pull it directly backwards until it releases.
    • Flip up the lock-bar on the ZIF connector, then gently pull the ribbon cable until it releases.
    • This requires almost no force.
  14. Dell Latitude 9510 Motherboard Replacement: 手順 14、 2の画像 1 Dell Latitude 9510 Motherboard Replacement: 手順 14、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the seven 4.0 mm screws.
    • Use a Phillips #00 screwdriver to remove the two 4.5mm screws.
  15. Dell Latitude 9510 Motherboard Replacement: 手順 15、 1の画像 1
    • Lift the motherboard up and out.
終わりに
作成者
3人の作成者と共同で作成されました。
Adam Sholar
メンバー登録日: 02/08/22
243 ポイント
2のガイドは作成済み
チーム
Western Carolina University, Team 1-5, Virtue Spring 2022 Western Carolina University, Team 1-5, Virtue Spring 2022人のメンバー
WCU-VIRTUE-S22S1G5
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 291
