はじめに
If you need to repair or replace the fan component in the Dell Latitude 7390, this guide shows you step-by-step how to access it.
Prior to starting this repair, be sure to turn off your laptop and unplug from the power adapter.
必要な工具と部品
Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
3 の人々がこのガイドを完成させました。
