メインコンテンツにスキップ
Dell Latitude 3520 Screen Replacement
必要な工具と部品
  1. Dell Latitude 3520 Screen Replacement, Remove MicroSD-card: 手順 1、 1の画像 1
    • Push the microSD-card to eject it from the slot.
    • Remove the microSD-card from the computer.
  2. Dell Latitude 3520 Screen Replacement, Bottom Case: 手順 2、 3の画像 1 Dell Latitude 3520 Screen Replacement, Bottom Case: 手順 2、 3の画像 2 Dell Latitude 3520 Screen Replacement, Bottom Case: 手順 2、 3の画像 3
    • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
    • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
    • Carefully lift and remove the base cover.
  3. Dell Latitude 3520 Screen Replacement, Screen Removal: 手順 3、 3の画像 1 Dell Latitude 3520 Screen Replacement, Screen Removal: 手順 3、 3の画像 2 Dell Latitude 3520 Screen Replacement, Screen Removal: 手順 3、 3の画像 3
    • Remove the 2mm Phillip #0 screw that secures the WLAN card bracket to the WLAN card on the system board.
    • Lift and remove the WLAN card bracket from the WLAN card that secures the two antenna cables.
    • Disconnect the antenna cables from the connectors on the WLAN card.
    • Disconnect and remove the WLAN card from the WLAN card slot.
  4. Dell Latitude 3520 Screen Replacement: 手順 4、 3の画像 1 Dell Latitude 3520 Screen Replacement: 手順 4、 3の画像 2 Dell Latitude 3520 Screen Replacement: 手順 4、 3の画像 3
    • Peel the adhesive tape, open the latch, and disconnect the I/O cable from the connector on the system board.
    • Lift and remove the I/O cable from the assembly.
  5. Dell Latitude 3520 Screen Replacement: 手順 5、 1の画像 1
    • Unroute the display cable from the routing guides in the assembly.
    • Peel the adhesive tape that secures the display cable in place.
  6. Dell Latitude 3520 Screen Replacement: 手順 6、 3の画像 1 Dell Latitude 3520 Screen Replacement: 手順 6、 3の画像 2 Dell Latitude 3520 Screen Replacement: 手順 6、 3の画像 3
    • Remove the one 4.55mm Phillip # 0 screw and six 2.5mm Phillip #0 screws that secure the display hinges to the system.
  7. Dell Latitude 3520 Screen Replacement: 手順 7、 1の画像 1
    • Lift the left and right hinges in an upward direction away from the assembly.
  8. Dell Latitude 3520 Screen Replacement: 手順 8、 1の画像 1
    • Lift the assembly off the display assembly.
終わりに
作成者
2人の作成者と共同で作成されました。
Shawn Smith
メンバー登録日: 09/08/23
871 ポイント
7のガイドは作成済み
チーム
University of New Orleans, Team 4-2, McDonald Fall 2023 University of New Orleans, Team 4-2, McDonald Fall 2023人のメンバー
UNO-MCDONALD-F23S4G2
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 26
過去 30 日: 104
今までの合計 670
