必要な工具と部品
Disconnect the battery cable from the motherboard.
Remove the 4 screws holding it in place
Battery can now be removed from device.
Unplug the fan header
Unplug the VGA board cable
Unplug the LCD cable
Once these 2 screws are removed the fan will lift out as long as the cables are out of the way.
Loosen the 7 screws in sequential order as labeled on the heatsink [1, 2, 3, 4, 5, 6, 7]
Lift heatsink out of device
To replace these screws: place the heatsink, line up the screw holes, then tighten the screws in the same sequential order labeled on the heatsink.
